engine stalls in gear at high rpm
Home  \  Repairs & Maintenance  \  engine stalls in gear at high rpm
I have a 90 mustang i put a 302 engine in it. It run fine at idle warming it up put it in drive and flooring the gas pedal and the engine stalls out.. i told off the the ICV and the EGRV and clean it and it still stalls out after flooring the gas padle
please help...
posted by  mustang90LX50
Got a check engine light?
[QUOTE=DodgeRida67]Got a check engine light?[/QUOTE
yes the check engine light is on
Then... pull the codes.
i pull the codes and i get 34, 67, 82, 85
34 = EGR Valve Position (EVP) sensor or Pressure Feedback EGR (PFE) sensor: signal voltage out of Self-Test specification limits. or, signal voltage above closed limit during normal engine run operation or signal indicates insufficient EGR flow.
67 = Improper signals are being received from either the Neutral Drive Switch (NDS), Neutral Gear Switch (NGS), Neutral Pressure Switch (NPS), Clutch Switch (CS), Manual lever Position (MLP) Sensor or air conditioner clutch (ACC) or, Air Conditioner (A/C) on during Self-Test
82 = Thermactor Air Bypass (TAB or AM-1) solenoid: circuit failure. or, Electro-Drive Fan: circuit failure. or Supercharger Bypass Solenoid (SBS): circuit failure.
85 = Cannister Purge (CANP) solenoid - circuit failure. or, Transaxle problem - 3/4 shift soleniod circuit failure. or, Electronic Control Assembly (ECA) status - adaptive "lean" limit reached in fuel control program.
