2000 Ford Ranger ABS
Home  \  Repairs & Maintenance  \  2000 Ford Ranger ABS
My 2000 Ford Ranger V6 super cab with 101,000 miles ABS brake light comes on intermittently only when the raods are wet. When roads are dry no problem. Any idease as to cause?
posted by  Craig
Verify ur connections. They may be dirty or u could have damage/spliced wires. U pretty much figured it out on ur own: moisture. Remove connectors and inspect them, Do this with the engine and ignition off. Repair as needed.
Also check if the ABS sensor itself doesn't have a crack or something on it. :thumbs:
posted by  Carcass
