Clutch problem
Home  \  Repairs & Maintenance  \  Clutch problem
I have a 1998 Nissan Altima, manual transmission. It has about 104K miles. Recently I started having problem with the clutch. When I press the clutch to switch gears, specially from 1st to 2nd and 2nd to 3rd, the tach does not drop all the way to 700rpm. Sometimes the tach drops a little and sometimes it just stays put when I change gears. Also sometimes when I press the clutch (to change gears) the rmp goes up. Does anybody know why this is happening? Do I need to change transmission fluid or I have something more serious? Any help is appreciated. Thanks
posted by  ckbsc
Your clutch may not be disengaging all the way, but just enough to slip. Take a look at the disk its self and see how thin it is or have a trans shop do it. Do it soon because if it is doing this it won't take long to wear out all the way and not move the vehicle at all. :2cents:
posted by  srober32
