Old 07-17-2005, 08:52 AM   #1
zinger54
Master or slave?
I have an '86 Ford Ranger. 2.9L , Fuel injected , 5 spd. My clutch pedel is leaking down while sitting at a red light with the pedel depressed, but I am not using any hydrolic fluid. ( I do not have to add hydrolic fluid to the clutch master cylinder). Correct me if I am wrong, but it would seem to me that if it were the clutch slave cylinder that was the problem it would be leaking. And if it was the clutch master cylinder being the problem , the plunger (or piston) could be letting fluid passby. Therefor no leaking fluid. Right?
zinger54 is offline   Reply With Quote
Old 07-17-2005, 06:31 PM   #2
BanffAutoSpa_ap
Pants The Ripper
BanffAutoSpa_ap's Avatar
yeah your right the seals in your master could be letting fluid by, ive seen it a few times but usually because someone put tranni fluid or motor oil in the master, which swelled the seals and rotted them very quickly, i think yours has an external; slave if i were you id throw on a new master and bleed the line, make sure you bench bnleed it first cuz the angle that they put those masters in is absolutely retarded and hard to bleed once it's in, or was that the s-10 ahh shit i can't remember, anyway goodluck, i would use factory parts cuz ive run into wierd shite with aftermarket pushrods not being long enough and slave cylinder bore sizes being different which will change the length of stroke on the slave
Old 07-23-2005, 10:47 PM   #3
As I understand it, a Slave cylinder and a Master cylinder, are the same thing.....
Old 07-23-2005, 11:02 PM   #4
dodger65
I know more than Wally...
dodger65's Avatar
he's right--ranger clutch master cylinders suck ass!
