Old 05-31-2007, 10:35 PM   #1
Desert_Elcamino
1973 El camino
hello i own a 73 El Camino and it has a 5.7 350 chevy and i want to upgrade it to a chevy 454. i was wondering would the motor mounts bolt right up or would they have to be moved around, if so how would i go about that. any info would be great thank you.
Desert_Elcamino is offline   Reply With Quote
Old 06-01-2007, 01:25 PM   #2
glagon1979
daddy x3
glagon1979's Avatar
being a chevy guy, i thought i would know this, but i dont. after asking around the shop, the guys here say yes it will bolt right in. the 73 el camino did come from the factory with a 454 so even if you had to move the mounts there will be holes in the frame that will accept that location.
this forum is to dead to share a cool sig with everybody....
Old 06-01-2007, 05:41 PM   #3
PontiacFan27
PontiacFan27's Avatar
To my knowledge there is only one small block 454 thats made, and its made by World Products. A regular 454 is a big block. It will not bolt right up.
Old 06-01-2007, 05:52 PM   #4
glagon1979
daddy x3
glagon1979's Avatar
why not?? trans bolts up the same, they use the same clam shell style motor mounts. tell me why they are different. and i want proof, not just you telling me.
Old 06-01-2007, 06:09 PM   #5
glagon1979
daddy x3
glagon1979's Avatar
upon a little further research, EVERYTHING will bolt up, BUT, you may have to shim your mounts on the block about 1/4" to 3/8". also be very carefull of hood clearance.
Old 06-04-2007, 12:48 AM   #6
tjtravis
tjtravis's Avatar
reply
Yeah it should bolt right up. Only time i usualy find they won't is on an american car when you get a block from over seas
Signature removed. No advertising! One warning only will be given! Please read the rules.
tjtravis is offline   Reply With Quote
Old 06-06-2007, 06:17 AM   #7
76MonteMan
76MonteMan's Avatar
From what I've been told, you will need to get big block motor mounts. You will also need to get big block springs for the front. You should get a Turbo 400 transmission to back the 454.
Dustin Denner
Owner: 1976 Chevrolet Monte Carlo Landau
1/4 mile ET: 14.45 seconds @ 94.37 MPH
0-60 MPH: 5.71 seconds
76MonteMan is offline   Reply With Quote
