Old 03-10-2005, 11:44 PM   #1
misskitty78382
Angry 2001 chev malibu
i have a 2001 chev malibu, my anti theif system has locked me out and my car wont start, have mecanic cant figure out how to disable it he put in new spark plugs lol (didnt need them) i had to down load him papers on problems with the theif devise,(lol) he still dont know how to fix it, i bet my bill will be hundreds of dollars and i did most the foot work on it , even taught his crew to go to the net on problems on cars when they cant figure it outr , can some one help my home town mechanic fix my car by disabling the anti theif alarm? does any one have a diagram on how to do it ? miss_kitty78382@yahoo.com
misskitty78382 is offline   Reply With Quote
Old 03-11-2005, 01:44 AM   #2
BanffAutoSpa_ap
Pants The Ripper
BanffAutoSpa_ap's Avatar
what engine? transmission ? more car specs
Old 03-11-2005, 01:45 AM   #3
BanffAutoSpa_ap
Pants The Ripper
nevermind i think they only came with the 3.1
Old 03-11-2005, 02:21 AM   #4
your anti-theft system should be built in to the body control module(bcm) or body function controller(bfc) location right side dash all so you must have a keyless entry system that module should be located in the trunk on the upper deck with the rear speakers the only way i have heard to bypass this is to replace the module with one from another malibu that didnt come with the anti theft system my repair manual only covers up to 2000 models i have a 97 found my problem was rusted ground plugs at the top mounting bolts of the transmission one above the starter and other is on the firewall side same hight bolt hole cured the problem with my anti-theft and my abs lights and for the post above they came with 2.4L 3.1L 3.4L
Old 03-11-2005, 02:26 AM   #5
BanffAutoSpa_ap
Pants The Ripper
in that year??? you sure aboot that? where do you live?
Old 03-11-2005, 02:40 AM   #6
my manuals only cover up to a 2000 and i'm in ontario canada well your right looked it up they dropped the 2.4L and the 3.4 out of the line up for 2001 and up
Old 04-03-2006, 10:52 PM   #7
dale g
Smile theft deterrent bypass
I own a 96 chevy lumina that lockedout with a secrity light that flashed. I was able to jump the soleniod and it ran about 5 sec. After some research I found that the problem probably waqs in the key switch. I accessed the wires by removing the panel under the steering column. I found what appeared to be an orange wire,this was actually two wires encased in orange.
As indicated by my researchthese were very light (about 20ga.) I disconnected these at the plug(bottom of dash) and ckecked for a complete circuit ($5 volt, ohm meter from local hardware) I found that this circiut was incomplete. I used the same tester to find the resistance of my key. Next was a trip to an electronics store (R.S.) I purchased the proper resistor to wire in place of failed switch. Total cost $7.00. $5.00 for meter and $2.00 for the resistors (10 purchased 2 used) good luck!!
dale g is offline   Reply With Quote
Old 04-25-2006, 06:05 AM   #8
raycorri
Talking Here's info for your mechanic to disable
Photos to access the wiring for your Passlock 2 are in the 5th post down in this thread. Hope this helps.
http://www.automotiveforums.com/vbul...d.php?t=454520
Ray
raycorri is offline   Reply With Quote
Old 09-02-2009, 07:50 AM   #9
exclusivelyVT
exclusivelyVT's Avatar
drug users rights
Hello rxtopyyrte
<a href=http://www.learninggateway.net/members/ORDER-GENERIC-ACCUTANE-DRUG-AND-SAVE-BIG/default.aspx>accutane cost</a>
accutane pills
http://sharepointmx.mvps.org/members...NE-ONLINE.aspx - generic accutane
<a href=http://drowningintechnicaldebt.com/members/ORDER-CIPRO-ONLINE/default.aspx>order cipro</a>
ciprofloxacin online
http://www.surfguru.com/forum/member...-SAVE-BIG.aspx - cipro 500
<a href=http://www.classicclashes.co.za/Community/members/BUY-CLOMID-ONLINE/default.aspx>clomid cost</a>
clomid cost
http://www.classicclashes.co.za/Comm...E/default.aspx - clomid for sale
<a href=http://blog.avanadeadvisor.com/members/ORDER+GENERIC+CYMBALTA+DRUG+AND+SAVE+BIG.aspx>cymb alta asthma</a>
cymbalta drug
http://drowningintechnicaldebt.com/m...G/default.aspx - cymbalta online
<a href=http://www.surfguru.com/forum/members/ABUY-DIFLUCAN-FLUCONAZOLE-NO-PRESCRIPTION.aspx>diflucan price</a>
diflucan no prescription
http://firsthandtechnology.org.uk/me...OLE+PILLS.aspx - diflucan no prescription
<a href=http://sharepointmx.mvps.org/members/DCHEAP-ZITHROMAX-AZITHROMYCIN-WITHOUT-PRESCRIPTION.aspx>doxycycline price</a>
doxycycline 100mg
http://drowningintechnicaldebt.com/m...G/default.aspx - doxycycline mg
<a href=http://www.surfguru.com/forum/members/AORDER-GENERIC-HOODIA-GORDONII-HG-P57-DRUG-AND-SAVE-BIG.aspx>hoodia 500</a>
hoodia weight loss
http://drowningintechnicaldebt.com/m...S/default.aspx - hoodia weight
<a href=http://firsthandtechnology.org.uk/members/ABUY+CYMBALTA+ONLINE.aspx>lexapro pharmacy</a>
cheap lexapro
http://sql-server-performance.com/Co...-SAVE-BIG.aspx - lexapro sale
<a href=http://sharepointmx.mvps.org/members/DORDER-CHEAP-NOLVADEX-PILLS.aspx>nolvadex for sale</a>
nolvadex 20mg
http://sharepointmx.mvps.org/members...EX-ONLINE.aspx - buy tamoxifen citrate
<a href=http://sql-server-performance.com/Community/members/DCHEAP-GENERIC-PREDNISONE--PILLS.aspx>prednisone cost</a>
prednisone medication
http://sharepointmx.mvps.org/members...NE-ONLINE.aspx - prednisone drug
<a href=http://firsthandtechnology.org.uk/members/DCHEAP+PROZAC+FLUOXETINE+NO+PRESCRIPTION.aspx>orde r prozac</a>
fluoxetine prozac
http://sql-server-performance.com/Co...AC-ONLINE.aspx - fluoxetine 20 mg
<a href=http://blog.avanadeadvisor.com/members/DCHEAP+RETIN-A+TRETINONI+NO+PRESCRIPTION.aspx>retin medication</a>
retin a acne
http://blog.avanadeadvisor.com/membe...SCRIPTION.aspx - retin a for acne
<a href=http://blog.avanadeadvisor.com/members/BUY+CYMBALTA+ONLINE.aspx>discount wellbutrin</a>
buy wellbutrin
http://www.classicclashes.co.za/Comm...E/default.aspx - buy wellbutrin
<a href=http://www.surfguru.com/forum/members/DORDER-ZITHROMAX-ONLINE.aspx>cheap zithromax</a>
buy azithromycin
http://www.surfguru.com/forum/member...AX-ONLINE.aspx - zithromax pills
<a href=http://www.surfguru.com/forum/members/DBUY-PREDNISONE-ONLINE.aspx>zoloft no prescription</a>
sertraline 50 mg
http://sharepointmx.mvps.org/members...SCRIPTION.aspx - sertraline medication
exclusivelyVT is offline   Reply With Quote
Old 09-02-2009, 07:50 AM   #10
exclusivelyVT
desi drug
Hello rxtopyyrte
<a href=http://www.learninggateway.net/members/ORDER-CHEAP-ACCUTANE-DRUG/default.aspx>accutane no prescription</a>
accutane without prescription
http://drowningintechnicaldebt.com/m...S/default.aspx - buy accutane
<a href=http://firsthandtechnology.org.uk/members/AGENERIC+CIPRO+ONLINE.aspx>cipro 500</a>
order cipro online
http://firsthandtechnology.org.uk/me...RO+ONLINE.aspx - cipro medication
<a href=http://sql-server-performance.com/Community/members/AORDER-GENERIC-CLOMID-PILLS-AND-SAVE-BIG.aspx>clomid price</a>
buy clomiphene
http://sharepointmx.mvps.org/members...ID-ONLINE.aspx - clomid for sale
<a href=http://www.surfguru.com/forum/members/ACHEAP-CYMBALTA-DULOXETINE-NO-PRESCRIPTION.aspx>cymbalta without prescription</a>
cymbalta drug
http://www.surfguru.com/forum/member...SCRIPTION.aspx - cymbalta medication
<a href=http://blog.avanadeadvisor.com/members/ORDER+DIFLUCAN+ONLINE.aspx>buy diflucan</a>
diflucan cost
http://firsthandtechnology.org.uk/me...SCRIPTION.aspx - generic diflucan
<a href=http://blog.avanadeadvisor.com/members/BUY+CIPRO+CIPROFLOXACIN+WITHOUT+PRESCRIPTION.aspx> doxycycline malaria</a>
doxycycline drug
http://firsthandtechnology.org.uk/me...SCRIPTION.aspx - doxycycline cost
<a href=http://firsthandtechnology.org.uk/members/ACHEAP+HOODIA+GORDONII+HG+P57++WITHOUT+PRESCRIPTIO N.aspx>hoodia weight loss</a>
buy hoodia
http://www.classicclashes.co.za/Comm...G/default.aspx - hoodia p57
<a href=http://www.surfguru.com/forum/members/DCHEAP-GENERIC-LEXAPRO-ESCITALOPRAM-PILLS.aspx>discount lexapro</a>
lexapro pill
http://www.surfguru.com/forum/member...SCRIPTION.aspx - lexapro antidepressant
<a href=http://sharepointmx.mvps.org/members/DGENERIC-NOLVADEX-ONLINE.aspx>nolvadex for sale</a>
cheap tamoxifen
http://www.classicclashes.co.za/Comm...E/default.aspx - nolvadex online
<a href=http://drowningintechnicaldebt.com/members/DBUY-PREDNISONE--WITHOUT-PRESCRIPTION/default.aspx>prednisone asthma</a>
http://sql-server-performance.com/Co...SCRIPTION.aspx - prednisone 20mg
<a href=http://www.surfguru.com/forum/members/DCHEAP-PROZAC-ONLINE.aspx>purchase prozac</a>
prozac anxiety
http://www.surfguru.com/forum/member...SCRIPTION.aspx - generic fluoxetine
<a href=http://blog.avanadeadvisor.com/members/DCHEAP+RETIN-A+TRETINONI+NO+PRESCRIPTION.aspx>cheap retin a</a>
retin a acne
http://blog.avanadeadvisor.com/membe...SCRIPTION.aspx - retin online
<a href=http://drowningintechnicaldebt.com/members/DORDER-GENERIC-WELLBUTRIN-SR-DRUG-AND-SAVE-BIG/default.aspx>order wellbutrin</a>
wellbutrin price
http://blog.avanadeadvisor.com/membe...TA+ONLINE.aspx - wellbutrin no prescription
<a href=http://www.surfguru.com/forum/members/DCHEAP-ZOLOFT-SERTRALINE-NO-PRESCRIPTION.aspx>azithromycin online</a>
zithromax medication
http://firsthandtechnology.org.uk/me...SCRIPTION.aspx - zithromax without prescription
<a href=http://www.surfguru.com/forum/members/DCHEAP-GENERIC-PREDNISONE--DRUG.aspx>generic zoloft</a>
zoloft price
http://sharepointmx.mvps.org/members...NE-ONLINE.aspx - zoloft for anxiety
Old 09-02-2009, 07:51 AM   #11
exclusivelyVT
list of blood pressue medicine
Hello rxtopyyrte
<a href=http://www.learninggateway.net/members/ORDER-GENERIC-ACCUTANE-PILLS-AND-SAVE-BIG/default.aspx>accutane no prescription</a>
acne accutane
http://drowningintechnicaldebt.com/m...E/default.aspx - cheap accutane
<a href=http://www.surfguru.com/forum/members/ABUY-CIPRO-CIPROFLOXACIN-NO-PRESCRIPTION.aspx>generic ciprofloxacin</a>
order cipro online
http://sharepointmx.mvps.org/members...RO-ONLINE.aspx - cipro drug
<a href=http://www.learninggateway.net/members/BUY-CLOMID-CLOMDPHENE-WITHOUT-PRESCRIPTION/default.aspx>clomid cost</a>
clomid price
http://drowningintechnicaldebt.com/m...N/default.aspx - clomiphene citrate
<a href=http://www.surfguru.com/forum/members/AORDER-GENERIC-CYMBALTA-PILLS-AND-SAVE-BIG.aspx>cymbalta asthma</a>
order cymbalta
http://firsthandtechnology.org.uk/me...+SAVE+BIG.aspx - order cymbalta
<a href=http://sharepointmx.mvps.org/members/CHEAP-DIFLUCAN-FLUCONAZOLE-WITHOUT-PRESCRIPTION.aspx>diflucan online</a>
diflucan drug
http://drowningintechnicaldebt.com/m...G/default.aspx - diflucan 150 mg
<a href=http://www.learninggateway.net/members/ORDER-GENERIC-CIPRO-PILLS-AND-SAVE-BIG/default.aspx>doxycycline price</a>
doxycycline for acne
http://blog.avanadeadvisor.com/membe...NE+ONLINE.aspx - doxycycline chlamydia
<a href=http://sql-server-performance.com/Community/members/AORDER-CHEAP-HOODIA-GORDONII-HG-P57-PILLS.aspx>hoodia hoodia</a>
buy hoodia gordonii
<a href=http://sql-server-performance.com/Community/members/AORDER-GENERIC-CYMBALTA-DRUG-AND-SAVE-BIG.aspx>lexapro without prescription</a>
http://www.classicclashes.co.za/Comm...G/default.aspx - discount lexapro
<a href=http://www.classicclashes.co.za/Community/members/DCHEAP-NOLVADEX-ONLINE/default.aspx>generic nolvadex</a>
http://firsthandtechnology.org.uk/me...SCRIPTION.aspx - nolvadex 20mg
<a href=http://drowningintechnicaldebt.com/members/DBUY-PREDNISONE--WITHOUT-PRESCRIPTION/default.aspx>order prednisone</a>
generic prednisone
http://drowningintechnicaldebt.com/m...G/default.aspx - prednisone drug
<a href=http://blog.avanadeadvisor.com/members/GENERIC+CYMBALTA+ONLINE.aspx>fluoxetine medication</a>
prozac mg
http://www.surfguru.com/forum/member...SCRIPTION.aspx - buy prozac online
<a href=http://blog.avanadeadvisor.com/members/DORDER+GENERIC+RETIN-A+DRUG+AND+SAVE+BIG.aspx>buy retin</a>
retin a acne
http://blog.avanadeadvisor.com/membe...SCRIPTION.aspx - buy retin
<a href=http://firsthandtechnology.org.uk/members/DLEXAPRO+NO+PRESCRIPTION.aspx>order wellbutrin</a>
wellbutrin without prescription
http://www.classicclashes.co.za/Comm...N/default.aspx - buy wellbutrin
<a href=http://www.learninggateway.net/members/CHEAP-CIPRO-CIPROFLOXACIN-WITHOUT-PRESCRIPTION/default.aspx>order zithromax</a>
order zithromax
http://firsthandtechnology.org.uk/me...+SAVE+BIG.aspx - zithromax azithromycin
http://www.surfguru.com/forum/member...NE-ONLINE.aspx - zoloft drug
