Old 03-03-2005, 12:22 AM   #1
Dreamcicle_7
Question !996 Geo Metro Altrenator Problems
I have a 1996 Geo Metro LSi, 4 Dr, Automatic, 4 Cylinder. I have had this car for over a year and its been a really good car until about a month ago. My alternator quit and since then I have had to put 4 alternators in it. The last one only lasted about 2 days. I can tell you that when I bought the car it had no speakers in it. My boyfriend at the time installed some used speakers in the car. Now when the alternator starts messing up the first thing to go is the radio. It wont turn off or anything and everytime I hit the brakes my radio sounds like static. Then my lights go and my wipers follow. No one seems to know what the problems is. Some one said maybe it was the voltage regulator and someone else said it is the wiring in the car. If anyone has any advice or knows what the problem may be please let me know. Thanks!
Dreamcicle_7 is offline   Reply With Quote
Old 03-03-2005, 01:23 AM   #2
thongsai
does fuses blow or does the light bulbs blow?
thongsai is offline   Reply With Quote
Old 03-03-2005, 01:52 AM   #3
BanffAutoSpa_ap
Pants The Ripper
BanffAutoSpa_ap's Avatar
whatever you do don't buy another alternator unless the one you currently have no longer works, if you can pull it out of the vehicle and test it individually from canadian tire or wherever you parts guys test there products, 4 in one year is absurd, an alternator will last more than 2 years and most manufacturers have a 2 year warrenty, it sounds like a wiring problem, or a bad battery. your car probably has an internal voltage regulator(inside the alternator which has to be replaced as an assembly... not always but it's usually the same cost as getting a new alternator) so unless your buying junkyard used alternators then you shouldn't be having any problem with your new alternator. i would say bad wiring, corroded or loose connections, or your b/f royally f-ed up the speaker job. but it shouldn't be going thru alternators like that so find a good mechanic and have em take a look.
Old 03-03-2005, 01:56 AM   #4
carls47807
wiring
My ford escort acted the same way. Wiring issues are probably the hardest to deal with because it is hard to find someone who has any clue what they are doing (myself included). If it were me, i would disconnect the junky speakers my boyfriend put in (which couldn't happen because i am a heterosexual guy) and probably even disconnect the radio to see how things work that way. From there I would have the alternator bench tested (as the last person said) to find out if it really is bad, and go from there. There are fusible links between the alternator and batteries on most newer vehicles which commonly blow when retards pull battery cables, or just from old age.
Do you have a voltage meter or idiot light in your vehicle, and if so what is it telling you?
Good luck.
carls47807 is offline   Reply With Quote
Old 03-03-2005, 02:06 AM   #5
BanffAutoSpa_ap
Pants The Ripper
[quote=carls47807] If it were me, i would disconnect the junky speakers my boyfriend put in (which couldn't happen because i am a heterosexual guy) QUOTE]
damn that was a good laugh.. thx buddy
Old 03-03-2005, 02:06 AM   #6
Is the regulator in the alternator? If not, that could be the cause.
Old 03-04-2005, 01:27 AM   #7
srober32
srober32's Avatar
You should have the battery charged before instaling a new altenator. The reason you have gone through 4 alts is because the battery does not have a full charge, when you start it the alt reads it as a drain and slams into full charging mode which tends to burn out the voltage regulator if the battery is not fully charged.
When replacing your altenator, make sure your battery is fully charged.
srober32 is offline   Reply With Quote
Old 03-04-2005, 10:18 PM   #8
Dreamcicle_7
Smile Thanks for the advice
Thank you all so much for the advice you gave me! I will look into everything you guys mentioned. My ex is probley responsible (He was an all out Dumb-Ass)But thank you. If I have any more questions I will be in touch!!!
Old 03-05-2005, 01:56 AM   #9
BanffAutoSpa_ap
Pants The Ripper
Most of em are
