Old 03-21-2005, 01:48 PM   #1
hobbyman
Question 1997 Mercury Sable - wheel bearings
I'm pretty much a novice at car repair but I do try to fix what I can.
Two questions:
1) What is the size of the bearing lock nut on the 97 mercury sable?
I have a 1-1/8" deep socket but it is larger than that.
2) Are the wheel bearings replaceable? If yes, how?
I have the haynes manual but it is no help in this area.
Thanks.
hobbyman is offline   Reply With Quote
Old 03-21-2005, 02:17 PM   #2
the axle nut could be 30mm 32mm or 36mm for the 30mm try 1 3/16 and 32mm try 1 1/4 and 36mm try 1 5/16 as for the bearings they are replaceable by a hub assembly or maybe it can be pressed apart to replace the bearings most machine shops can do this pressing part
my new toy
