Old 02-11-2005, 12:47 AM   #1
'89Camry
Shameful Question
I'm almost embarassed to ask this, but not-being a huge car guy... i think it's acceptable. Anyway, what should my tire pressure gauge read when I check my tires? The question applies to my '89 camry....
Thanks alot for your help, this site has been good to me...
'89Camry is offline   Reply With Quote
Old 02-11-2005, 12:52 AM   #2
pornking
there's always a tire pressure list at the gasstation ???
you can find the pressure for the most common cars on there
No Advertising!
Please delete once read!
pornking is offline   Reply With Quote
Old 02-11-2005, 01:08 AM   #3
lectroid
0000?
lectroid's Avatar
If you can't find a sticker on the door or door post and/or owners manual. Keep pressure at 32 PSI till you can find out the correct pressure. That should be safe.
Old 02-11-2005, 08:11 AM   #4
NISSANSPDR
and the Revolution
NISSANSPDR's Avatar
Keep in mind your tires also say your Max PSI you can use...so dont ever go over that...if it says 46 for instance...you should be around 36...but if that's too hard for you...go down to 32...play around and see what you like/is comfortable to you
About 60% of accidents on the road occur due to improper pressure in the tires...either too much or too little...remember...your 4 tires are the only thing in contact (hopefully) w/the road...keeping them at the correct pressure is KEY.
Yours truly,
Gabriel
NISSANSPDR is offline   Reply With Quote
Old 02-11-2005, 09:07 AM   #5
They should be within 28 and 32 psi. Call up a Toyota dealer and find out.
Old 02-12-2005, 12:57 AM   #6
Nichol Bolas
Nichol Bolas is offline   Reply With Quote
Old 02-21-2005, 06:02 PM   #7
'89Camry
You're right, I found it in the door pannel. Thanks everyone.
