Old 11-23-2005, 05:53 PM   #1
Robyn
Unhappy 1996 Pontiac Sunfire GT
Hi there,
I have a 1996 pontiac Sunfire GT and I beleive there is something wrong with my ABS breaks. Whenever it rains or is a little wet out and I break the ABS breaks come on, and my tires lock up. It is extra sensitive, I don't break hard at all? Any thoughts on what the issue is?
My mechanic said that he couldn't look at it until it's wet outside...Please help!
Robyn is offline   Reply With Quote
Old 11-23-2005, 08:41 PM   #2
carlos
Originally Posted by Robyn
Hi there,
your tires aren't too worn are they? excessively worn tires tend to "slip" when wet even under moderate braking conditions.
carlos is offline   Reply With Quote
Old 11-23-2005, 08:43 PM   #3
Robyn
New tires
No, I have good Toyo Tires, they are new??
Old 11-23-2005, 08:58 PM   #4
67Coronet383
CF Riff Master
67Coronet383's Avatar
Hi there,
I think you're having trouble with the proportioner.
Old 11-23-2005, 09:18 PM   #5
Robyn
Do you think it could also be a leaky wheel cylinder and brake fluid is getting on the shoes/drums?
Old 11-23-2005, 09:58 PM   #6
BanffAutoSpa_ap
Pants The Ripper
BanffAutoSpa_ap's Avatar
if the shoes are contaminated with dif oil and as you slightly touch the brakes and blamo lockup, your abs is probably working properly, yes you have to fix the wheel cylinder and get new shoes before you diagnose an abs problem, i would think the abs is fine and the brakes are hooped.
Old 11-23-2005, 10:07 PM   #7
Robyn
But would that cause the ABS breaks to pump? Because when the wheels lock I feel that pumping.
Old 11-23-2005, 11:53 PM   #8
carlos
ABS systems will "electronically" pump the brakes. In the old days people would pump the brakes on vehicles in order to prevent then from locking up. Nowadays the hydraulic control unit(HCU) contains inlet and outlet valves that are controlled by the ABS module which cycles them on and off to stop and allow fluid to flow to your calipers/wheel cyl. That pumping action that you feel happens when the inlet valve opens and closes and is completely normal with ABS operation.
Old 11-24-2005, 01:50 AM   #9
BanffAutoSpa_ap
Pants The Ripper
Yes, your abs is meant to pump when it sees a wheel locked, i could use alot of jibba jabba terms here and spew alot of verbal diahrea but all you need to know is if one wheel is locking up because of any number of reasons, the abs system will try to pump the brakes for you so that you have control in an emergency situation. is the wheel cylinder leaking? has it gotten brake fluid all over your shoes(not your running shoes), if so..... fix that first, that would be your first place to start on this repair job.
Old 11-24-2005, 02:51 PM   #10
Robyn
Thanks
Thaks to everyone for all your help
Old 02-14-2008, 10:22 AM   #11
RobynA
I also have the same problem with my 1996 Sunfire Gt. They lock up and kinda jolt when wet with snow or rain too. My mom has a 1998 Sunfire, and it does the same thing, as well as my sister-in-laws mothers 2000 Grand Am. I personally think its just the way the brakes are in the Pontiac cars, because we all have good breaks, tires, and dont brake hard. They dont do it when they are dry, so it has to have something to do with the water, and the ABS system on these cars, because really, how can there be something wrong with all three cars that are taken care of, that would cause a problem like this. I find if they are wet, and you brake gently and slowly, then there isn't a problem with them.
RobynA is offline   Reply With Quote
Old 08-24-2008, 10:41 PM   #12
cav_rider666
Unless you deactivate the system, your stuck with it. The ABS on the 1995-2004 cavaliers/sunfires kicks in all the time, espacially when its raining or snowing out.
cav_rider666 is offline   Reply With Quote
Old 08-24-2008, 10:46 PM   #13
dodger65
I know more than Wally...
dodger65's Avatar
it's like it only does it in potentially slippery conditions.. it's just crazy!
