Old 06-18-2003, 04:20 AM   #1
403_CHEVY
403 300+hp help
hey what's up everyone. I need some help my causins just gave me there olds 403 and i wanted to get it up to 300+ hp but the only problem is that it has to pass smog. i was thinking of an edelbrock perfomer rpm intake and cam with an edelbrock carb, but i dont think that'll pass the smog test. Do you guys have an suggestions on how i could reach my goal?
thanks
check out my project truck
http://members.cardomain.com/80_305_chevy
403_CHEVY is offline   Reply With Quote
Old 06-18-2003, 01:16 PM   #2
Re: 403 300+hp help
thanks
Not enough info. What state are you in? What year car will it be going in? What else if anything has been done to the engine?
Old 06-19-2003, 12:18 AM   #3
403_CHEVY
i'm from cali, the engine is still stock right know and it's gonna be going in a 1980 chevy scottsdale
Old 06-19-2003, 03:13 AM   #4
First I have to say I'm not 100% current on California emissions regs. When I lived there you had to meet regs for the vehicle or engine, whichever was newer. I understand that has been changed to year of vehicle only.
Your '80 Chevy is not exempted because it's not yet 30 years old so let's assume you have to meet 1980 regs. Depending on what part of the state you live in you have the annual or bi-annual smog check. To pass this you'll have to not only get by the sniffer but also the visual. That means you'll have to have in place and working EGR, vapor canister, catalytic converter, PCV, etc. Also any aftermarket parts will have to have a CARB number with documentation.
All that being said you should be able to get 300hp with a good intake, 600cfm carb, mild cam, headers, and probably a quick polish on the heads. I can't give you much in the way of specifics as again I'm not sure what is legal. Keep in mind a 403 isn't so much a horsepower engine as it is a torque monster.
Another quick point. I hope you got a transmission to go with it. The BOP bolt pattern is different from a Chevy and I've never seen a Chevy truck come with the dual bolt pattern bellhousing. Good luck.
Old 06-19-2003, 04:41 AM   #5
403_CHEVY
thank's a lot for taking the time to respond, i think i'm gonna go with your suggestion, yeah i'm going to change the tranny.
thanks
