Old 02-16-2006, 04:41 AM   #1
Aondor
Aondor's Avatar
460 swap
Today I found an old ford F150 with a 460engine the seller only wants 600 dollars and shes in beautiful shape.
Could I swap in the 460 from the truck into my comet then put my comets straight 6 in the truck and sell the truck?
I thought this would be a good idea since I could make some of my money back
Aondor is offline   Reply With Quote
Old 02-16-2006, 04:48 AM   #2
Put the 460 into the Vomet and then part the truck out. Less work, more money. Don't expect it to be easy making a 460 fit into your car.
Old 02-16-2006, 05:11 AM   #3
Aondor
Aondor's Avatar
Well I figure I have the engin mount etc to use from the truck. WIll my transmission handle and how do I tell what type of transmission I have.
I also need to replcae my front suspension to be able to handle the weight so its going to be alot of work a 351 would be a much easier swap but I was interested because of the deal offered on the truck
Old 02-16-2006, 05:46 AM   #4
Remember what I told you about that Maverick/Comet? In order to put the 460 in there you ned to notch the shck towers and get custom mounts fabbed (the engine side of teh truck will work, but you need custom mounts on the chassis to bolt them to). there are special headers for that swap, and you need a trans FOR that 460 (and not the truck one, unless it's a C6).
Then you need a driveshaft made, which isn't a BIG deal at any local driveshaft shop.
Then you'll need a better rear end before you build up the 460, as teh 6 cyl rear is a bit weak. Luckily, you can get 9" rears set up to go in that car, but you'll have to do a search on it.
Like I said, that's a swap I'd been contemplating, myself.
Old 02-16-2006, 07:02 AM   #5
Aondor
Aondor's Avatar
Well then I have someone I can ask questions. I may not be extremly knowledgeble but I am mechanically inclined and have alot of connections friends willing to help me out
Old 02-16-2006, 07:06 AM   #6
Aondor
Aondor's Avatar
where would i find 9" rears?
And Im correct on the required suspension upgrade right? Mustang2 suspension is what I need correct?
Old 02-16-2006, 07:09 AM   #7
Aondor
Aondor's Avatar
Overall cost of this project is around how much?
Old 02-16-2006, 01:34 PM   #8
Pythias
Pythias's Avatar
Do you know what the edit feature is, or do you simply not use it?
"Though I drive through the valley of rice,I shall fear no turbo for torque art with me. Thy rod and piston, they comfort me."
"It is not the strong who will win, but the winner who is strong." -ROTK7
"You wrote "The World Doesn't Need A Savior" but everyday I hear people crying for one."
Pythias is offline   Reply With Quote
Old 02-16-2006, 07:34 PM   #9
Aondor
Aondor's Avatar
Whats edit feature?
Old 02-16-2006, 09:50 PM   #10
Whats edit feature?
At the bottom of your posts, next to quote, it should say edit...So that you can edit your posts...
Old 02-16-2006, 10:34 PM   #11
Pythias
Pythias's Avatar
Instead of posting 3 things at once like you just did, only when people have posted after you and they may not see your edit should you post again....
