Old 10-02-2006, 01:57 PM   #1
bottell
Unhappy Overheating when in slow moving traffic.
Can any one help a dumb blonde. I have found that when I am moving in slow moving traffic or my vehicle is stationary with the engine running, the temperature with in the engine will overheat and my stop warning light comes on. After a few seconds the fan will kick in and it will cool down. When I am travelling in normal traffic its fine, as the cool air will keep it cool. I have had the temperature thermostat replaced , but this has not helped at all. Please help !!!
bottell is offline   Reply With Quote
Old 10-02-2006, 06:04 PM   #2
glagon1979
daddy x3
glagon1979's Avatar
is your check engine light on??
glagon1979 is offline   Reply With Quote
Old 10-03-2006, 12:53 PM   #3
TokyoJoe
TokyoJoe's Avatar
Radiator could be sludged or system may need flushed, i'm assuming was done with the t-stat? What type of car? Pump may need replacing.....
TokyoJoe is offline   Reply With Quote
Old 10-23-2006, 10:01 PM   #4
smiley100480
perhaps you can invest in getting an electric fan put in. my husband has done that, so that way there is air cooling the engine the whole time, even when stopped in traffic. hope that helps somewhat .
smiley100480 is offline   Reply With Quote
Old 10-23-2006, 10:59 PM   #5
Valter
Valter's Avatar
That is not a good thing to do.
The engine needs to work in a defined temperature. Not less, not more.
I'd suggest to bleed the coolant solution and/or remove any air that might be in the system.
Valter
FIAT Tempra Stile 1995
165bhp@5250RPM
200lb.ft@3000RPM
Valter is offline   Reply With Quote
Old 10-24-2006, 01:00 AM   #6
smiley100480
hey, i try. lol. my husband did suggest taking a look into the sensor??? i just know when a car overheats, its a huge pain in the ass.
Old 10-24-2006, 01:03 AM   #7
Valter
Valter's Avatar
hehehehe don't worry...
The sensor would be a good shot.
However, I still don't believe that's the case, since the fan does kick in after some temperature... This usually indicates there's air in the cooling system.
Check the sensor too! It might have gone bad and might be "reading" a wrong temp.
Valter
165bhp@5250RPM
200lb.ft@3000RPM
Old 10-27-2006, 07:34 PM   #8
If there was air in the cooling system the fan wouldn't cut in at all, or I've never known them to anyway!
Although she'll probably not be back, I'll chime in anyway, lol. When you say that the engine overheats, does it actally overheat to the extent that you have steam belloeing from the engine bay? I just wondered, as you said the STOP light comes on, but you don't say how hight the guage is reading!
I'll move this, too!
Old 10-28-2006, 12:54 PM   #9
glagon1979
daddy x3
glagon1979's Avatar
why is it not a good idea? they make universal fans that you can set to come on when the engine needs it to and shut off when a desired temp has been reached. i have one on my 81 monte carlo (that originally didnt come with one) and it works fine.
Old 10-29-2006, 10:28 PM   #10
dodger65
I know more than Wally...
dodger65's Avatar
what kind of car are we talking about anyway?
Old 10-31-2006, 01:38 PM   #11
Valter
Valter's Avatar
Isn't that what comes stock on the car?
Valter
165bhp@5250RPM
200lb.ft@3000RPM
