Old 07-15-2005, 11:03 PM   #16
The Capo
answer this
i wanted to know if I can put an Accord engine into a civic Lx 1994 4door
The Capo is offline   Reply With Quote
Old 07-15-2005, 11:05 PM   #17
FordFromHell351
FordFromHell351's Avatar
That car is still probably going to be slow after your mods are done unless you do something big to it, because its a heavy 4 door and only has a 4cyl. I would suggest starting with a cold air intake, header, exhaust system, and plugs and plug wires.
FordFromHell351 is offline   Reply With Quote
Old 07-15-2005, 11:06 PM   #18
FordFromHell351
Im pretty sure thats possible. Not much stress I wouldnt think.
Old 07-15-2005, 11:07 PM   #19
The Capo
thanks a lot! well i need an new engine for it and i wanted someting better, maybe i'll go V-tec??
Old 07-15-2005, 11:11 PM   #20
FordFromHell351
Yeah, VTEC would do it some good. B18 block.
Old 07-15-2005, 11:20 PM   #21
The Capo
thanks alot
Old 07-15-2005, 11:23 PM   #22
FordFromHell351
thanks alot
Also, make sure it comes out of a Honda Prelude, not an Integra. The Preludes always had bigger engines.
Old 07-16-2005, 12:52 AM   #23
HyundaGuy
Relicensed n ready 2 race
HyundaGuy's Avatar
whoa dudes.. if yall are even thinkin' about a turbo conversion then there's tons of work to be done, starting off with an ecu, new headers/manifolds, new combustion chamber lay-out, blue printing the lower block, new seals, new exhaust for a lower compression, new internals for a lower compression, you'll need to re-build your engine bay to be able to hold all the new parts and accessories.
new accessories consist of:
turbo
blow off valve
new manifold
new cold air intake
dump pipe
new mounts
strut bar
... all that just for a small 50hp upgrade..?
if i was you i'd be lookin' for a supercharger for the engine.. what ever it may be.. h22/h23/b18... anyway... still.. if i was you i'd be doin' an engine transplant with a b18c5 and then building it for a high compression and high torque... i've heard rumors that a b18c5 w/o forced induction.. is capable of around 320hp... maybe more.. maybe less..
If i still owned an excel.. It'd look like this:
HyundaGuy is offline   Reply With Quote
Old 07-16-2005, 01:14 AM   #24
The Capo
what if i get a H22A VTEC Engine or should i just got with the civic v tec and get it supercharged
Old 07-17-2005, 08:15 AM   #25
HyundaGuy
HyundaGuy's Avatar
depend's on what you want to use the car for, is it goin' to be a show car? drag car? street car? track car? time attack car?.. what's the car's main purpose?... depending on the desired choice for the vehicle, depend's on the answer...
i think i speak for everyone when i say "we need to know what you want it for before we can sugest things"... yeah..
