Old 11-19-2004, 01:11 AM   #16
DodgeRida67
DodgeRida67's Avatar
Originally Posted by Flame Roller
Then someone has clearly misinformed me about what differential is which.... what do stock 97 'stangs come with.... with power from only 1 wheel? I could very easily be wrong if someone somewhere in life has told me that that type of differential was limited slip...what is it really?
His point was you were relating an engine and differential to closely. He was saying an engine doesnt "come with" an LSD but a differential does. Think about it...
DodgeRida67 is offline   Reply With Quote
Old 11-19-2004, 02:31 AM   #17
Flame Roller
Ahh...
I can see where I was foolish in my wording, but do the differentials on a v6 97 stang come with limited slip then generally?
Flame Roller is offline   Reply With Quote
Old 11-23-2004, 09:39 PM   #18
Sick88Tbird
Master of the Fox-chassis
Sick88Tbird's Avatar
In that $1500 estimate I gave previously, I neglected to say a lot of things. $1500 is assuming he does the work himself and includes the price of a posi and gear-set of his choice. 94-95 Mustang GT's on average run about 14.9's, bone stock...where you people are getting mid-14's from is beyond me...the automatic GT's are even slower. His V-6 is lower on power than the later models, but that's mostly in the intake and heads.
It's not all about dropping a big motor in a car...88 T-bird Turbo coupe 5-speed VS. 88 T-bird with the standard 5.0...140hp/185lb-ft VS. 165hp/250lb-ft, respectively...those cars would run neck and neck in stock trim(low-16's). Considering the differences, the cars balance out well...the Turbo Coupe was packing around 16lbs of boost at max with a 3.73 posi rear and a weight of around 3150lbs....the standard granny-issue 5.0 T-bird had a soft-shifting AOD with a 2.73 "open" rear and a weight of about 3500-3700lbs.
New Toy- Stone stock '88 T-bird Sport in need of some TLC
1988 Cougar XR-7- HO/T-5 conversion, cracked block prevented from reaching full potential.
RIP '88 T-Bird....14.1@98.7mph...best sleeper in So. Jersey, now it's taking a permanent dirt nap.
Sick88Tbird is offline   Reply With Quote
