Old 11-29-2005, 01:49 AM   #16
It's Honda...all Honda's have V-Tech JK
Not all...my moms HX dindt have one...but it did have a one speed tranny...CVT
Old 11-29-2005, 02:02 AM   #17
Do you have a big, bright red tattoo on your forehead that says MORON? If not, you should. What do you thing CVT stands for Twinkie? If you said anything other than Constantly Variable Transmission... Well it wouldn't surprise me if you said something else.
Old 11-29-2005, 02:10 AM   #18
Yes I "thing" that it does have only one speed. Better yet I know so because when I drove it I had foot to the gas from 0-75 and there wasnt a single shift. The RPM didnt go over 4500 a single second.
1-speed cvt w/OD
A continuously variable transmission (CVT - also known as electronic CVT or eCVT) eliminates the gearing, and the shifting between gears, of a traditional transmission. Power from the engine is transmitted by a drive belt system connecting two conical pulleys. As the driver operates the throttle, the belts slide up and down the pulleys, creating a continuously variable gear ratio that is proper for the moment. The operation is seamless, with no upshifts or downshifts.
Old 11-29-2005, 02:16 AM   #19
1-speed cvt w/OD
Your text book answer just proved you wrong. The key words are "continuously variable gear ratio". That in terms you can understand equals "lots of speeds", not just one. MORON!
Old 11-29-2005, 02:21 AM   #20
95civicdima
95civicdima's Avatar
Definetly has a v-tec in it! Thanks though
95civicdima is offline   Reply With Quote
Old 11-29-2005, 02:31 AM   #21
And it also says 1-Speed
Old 11-29-2005, 02:32 AM   #22
Really, where is that? Link me to it.
Old 11-29-2005, 02:38 AM   #23
http://research.cars.com/go/crp/feat... 7&aff=latimes
Transmissions
5-speed manual w/OD Standard
1-speed cvt w/OD Optional
Says it right there.
Old 11-29-2005, 02:41 AM   #24
Transmissions
Cars.com is not a valid sight for research. Give us a collective break. Show me some Honda literature that calls it a one-speed. Better yet, read these and tell us where they're called one-speeds.
http://en.wikipedia.org/wiki/Continu...e_transmission
http://auto.howstuffworks.com/cvt.htm
Old 11-29-2005, 02:57 AM   #25
Notice I said " JK"
Old 11-29-2005, 03:08 AM   #26
torinoman80
Notice I said " JK"
Obviously not.
torinoman80 is offline   Reply With Quote
Old 11-29-2005, 04:18 PM   #27
PontiacFan27
PontiacFan27's Avatar
Minor fix
Continuosly Variable Transmission.
PontiacFan27 is offline   Reply With Quote
Old 11-29-2005, 05:54 PM   #28
Originally Posted by PontiacFan27
Minor fix
Thank you. I was so pissed at the little twit when I typed that I obviously wasn't paying attention.
Old 11-29-2005, 07:02 PM   #29
PontiacFan27
If anything, CVTs are million-speeds. 1 speed im guessing is just the simple way cars.com chose to classify it.
Old 11-30-2005, 03:49 AM   #30
Nissan_Altima
Biggest anti-post whore
Wow! I've heard of these transmissions before, but never knew how much it worked or anything about it in detail. Is it rare or I'm just unfamiliar with it?
Also, for pure curiosity, what's the generalization on them? How often do they break down compared to regular automatic/manual transmissions? Because it sounds as if they are more comfortable than the regular transmissions.
Nissan_Altima is offline   Reply With Quote
