Old 08-21-2005, 01:53 AM   #1
punk_rocker87
1995 kia sportage problums
hello evryone i have a 95 kia sportage and it has no power at all..it can barley make it up hills..the more gas you give it the slower it goes and rides the gears longer..i cant seem to find the psark plugs to see if 1 isint fireing or what so any help is apreciated thanks laote
punk_rocker87 is offline   Reply With Quote
Old 08-21-2005, 03:17 AM   #2
Sorry bro but I found your problem, I had one and they are no fun to go up hills with
Old 08-21-2005, 04:18 AM   #3
sentry
Kia Sportage
Hey,
I have a 97 Kia Sportage and I've had the same probelms that you've had.
Take it to a Auto place that has a computer that could tell you what to look for in fixing it.
Like at AutoZone or something.
The test is free.
OKay, the same exact probelm has happened to mine, so far this is what I've done to mine.
I've replaced both coil packs , cause I was told one was bad, though still the same problem.
Then I changed the spark plug , which was firing arm number 4 that wasn't doing well.
Then I changed the water pump, still to no avail, it's still messed up.
I'm taking mine back to the dealership Monday and I'll keep you posted.
The next idea from here would be look into your fuel line , or then look into the ERG Valve.
Good luck.
Jackie
(Sentry)
ps. my kia is a 97 model.
sentry is offline   Reply With Quote
