Old 08-22-2005, 01:00 AM   #1
mybrokendownzx2
should i shoot it?
im having a serious problem, i took my car to get the ac fixed, when i pulled into the mechanics driveway the car quit, and hasnt started since, its getting spark, but no fuel, we checked the emergency shut off in the trunk, we have replaced the fuel pump, filter, the ecm thats under the airbox, camshaft sensor, crankshaft sensor, fuel pump relay, and the ac relay...... we also checked the injectors, they were not pulsating, i think the only thing we have left to replace is the cars computer.it is a 1998 ford escort zx2, 2.0 litre, automatic trans car has only 68k miles, please help me, im going broke trying to please my wife!!
mybrokendownzx2 is offline   Reply With Quote
Old 08-22-2005, 01:31 AM   #2
Well this actually has me stumped....have you flushed the gas tank?
Old 08-22-2005, 01:48 AM   #3
Macc
What type of car is it?
There is likely an ecm(computer) relay. If the relay is goes south it can shut down the injectors, fuel pump, ecm, and the air flow sensor and cause your type of problem. Also if the maf (mass air flow) sensor is going, it will give the ecm incorrect air flow and cause engine problems. In addition on many engines a single fuse may be for several different sensors (such as the o2 sensor and the IAC). If that fuse is bad or corroded etc. then various sensors will not work properly and the ecm will read it as one or more bad sensors and cause engine problems. Do some searching, one of these might just be your problem!
Macc is offline   Reply With Quote
Old 08-22-2005, 12:07 PM   #4
tbaxleyjr
Macc is right on this one - please read the advice/rules, etc. at the top of the forums page concerning information - no one can help if we dont know what kind of car, engine, tranny, and specific symptoms, etc
tbaxleyjr is offline   Reply With Quote
Old 08-22-2005, 12:52 PM   #5
mybrokendownzx2
Originally Posted by mybrokendownzx2
im having a serious problem, i took my car to get the ac fixed, when i pulled into the mechanics driveway the car quit, and hasnt started since, its getting spark, but no fuel, we checked the emergency shut off in the trunk, we have replaced the fuel pump, filter, the ecm thats under the airbox, camshaft sensor, crankshaft sensor, fuel pump relay, and the ac relay...... we also checked the injectors, they were not pulsating, i think the only thing we have left to replace is the cars computer. please help me, im going broke trying to please my wife!!
oops, its a 1998 ford escort zx2, we have tested all fuses, but we have not drained the fuel tank yet, ill give it a try, thanks
Old 08-22-2005, 12:56 PM   #6
mybrokendownzx2
its an automatic trans, 2.0 litre with only 68k miles
Old 08-22-2005, 02:28 PM   #7
osborste
the canuck tech
osborste's Avatar
is there power to the injectors will the ecm ground the other wire?
theres 2 fuses 15amp engine and 30 fuel injectors providing power to a constant control relay module this unit will supply a signal voltage to the ecm as well power to the injectors/idle control valve/egr vacuum regulator and other sensors. the ecm will get a signal from the crank sensor to ground the injectors
without seeing or hearing your problem all i can do is offer advice on what to check
my new toy
<Link removed>......Please read the rules on advertising!
osborste is offline   Reply With Quote
