Old 03-27-2005, 06:51 PM   #1
vz9c6c
99 cavalier won't start w/ key...
I am having problems with my 99 cavalier. I can get the car started by using my after market remote start, but if I were to use my ignition key it doesn't even try to crank over. I think it's an ignition switch problem, but I am not sure. Please help...
vz9c6c is offline   Reply With Quote
Old 03-27-2005, 08:32 PM   #2
have the wiring checked most time's it's the way the remote starts are put in cut wire's splice and tape not soldered and heat shrinked tubing
my new toy
Old 03-28-2005, 04:40 AM   #3
srober32
srober32's Avatar
Yup, how long ago was the remote start installed?
When replacing your altenator, make sure your battery is fully charged.
srober32 is offline   Reply With Quote
Old 03-28-2005, 06:26 AM   #4
vz9c6c
the remote start was installed about five years ago, and it's been working great. all of the sudden this problem came up. Litteraly over night...Thanks in advanced for any info and advice.
Old 03-28-2005, 06:57 AM   #5
the lobster
suggestions
there is a relay that will disable the key start,when you use the remote.
if the relay has gone bad ,it is not closing the starter loop on the key circuit.
these are usually dpdt type.(double pole double throw.).check and make sure one of the clips has not fallen off.if it is not the relay,and it is the brain,you will have to see if the manufacturer is still in business .check with the people that put it in.....you might have a valet switch,too that you can try to see if it will start.
the lobster is offline   Reply With Quote
Old 03-28-2005, 11:39 PM   #6
vz9c6c
checked the relays and everything is good. I finally broke down and took it to a dealer and the mechanic told me that it is in my ignition switch. But thanks for all the help.
