Old 04-30-2006, 06:11 PM   #1
darreyll
engine stumbles on acceleration
What would cause a 1999 ford mustang v6 to stumble and stall out after 10 minutes of running the ac and how do you fix it? it only happens after i turn on the ac
darreyll is offline   Reply With Quote
Old 05-01-2006, 02:50 AM   #2
Sick88Tbird
Master of the Fox-chassis
Sick88Tbird's Avatar
That sounds like a bad ground some where...clean your batter cables/posts and check any chassis grounds you can find...clean 'em up and see where you stand.
New Toy- Stone stock '88 T-bird Sport in need of some TLC
1988 Cougar XR-7- HO/T-5 conversion, cracked block prevented from reaching full potential.
RIP '88 T-Bird....14.1@98.7mph...best sleeper in So. Jersey, now it's taking a permanent dirt nap.
Sick88Tbird is offline   Reply With Quote
Old 05-01-2006, 03:29 AM   #3
BubbaJones
Wink
It sounds like your car is stalling because of too much power being lost from the a/c when on.. I Think you should check out The High idle switch for the a/c.. It's mounted on your throttle body. When your car is at idle and you turn the a/c on Does the idle pick up 150-200 Rpm?? If your idle don't increase the switch is either out of adjustment this would only be out of adjustment if it has been removed etc. More then likely if your idle don't increase the a/c switch is bad. I hope this Helps
BubbaJones is offline   Reply With Quote
Old 05-01-2006, 03:42 AM   #4
I can assure you that although you hope it might help, it doesn't. High idle switch on a '99 Mustang 3.8? Where did you get that information from? Better get your facts straight and have some clue as to what you're talking about BEFORE you start giving advice.
