Old 08-25-2006, 05:58 AM   #1
flashgordon
93 Honda civic no start!
I wrecked my Honda 6 1/2 years ago and just got the body work finish last week!
I gess i should explain the crash first! Big farmers fork lifts arm or fork when thru the hood, thru the valve cover,drivers side strut tower,wiper arms, and windshield!
now i have replace the valve cover(lucklly it didn't touch the valve train!) my body man fixed the rest and the car.
but now it will not start,turns over just fine, but will not start!
sprayed carb spray and it will start and die!
check fuel pump and there was flow but no pressure!
replace the pump to night and now i have a lot of pressure but still no start.
check the spark plug wire for spark(i know, if it will run on carb spray it has spark)It has spark.
check fuel at fuel rail and it had pressure there also check the injector wires at the conector of the injector it's self, and thay have 12v (will light a test light!)with the key on but no ground with key on, or with eng cranking.
Have checked all the fuses...that i now of, with a test light and thay are all good! (the box next to the battery and the fuses under the steering coulmn......any ether ones???)
What sensors tell the computer to fire the injectors????
is there a hidden fuse next to the computer or a crash sensor....like Ford uses that need to be reset?
O ya i allso drained all the nasty old fuel out of the tank while i was replaceing the pump.......Has 5 gal fresh gas in it!
flashgordon is offline   Reply With Quote
Old 08-25-2006, 02:09 PM   #2
flashgordon
Ok, I have been doing some searching on this sight but still can find the answer.....just more question
Were is the main power relay and would my fuel pump run if this was bad?
Old 08-26-2006, 12:09 AM   #3
flashgordon
theres got to be some one out there that can help!!!!!
any one have a pdf file of the [U]wiring scmatic![/u]
Old 08-26-2006, 04:12 PM   #4
flashgordon
Hellooo hello......is there any body out there,is there any one at home!
Old 08-28-2006, 01:24 AM   #5
flashgordon
bump,bump,bump,
Old 08-28-2006, 02:01 AM   #6
It shouldnt take 6 and a half years to repair a cathedral let alone a 93 civic.
Old 08-28-2006, 02:32 AM   #7
torinoman80
And if we could understand his first post he wouldn't have posted 5 times in a row...
torinoman80 is offline   Reply With Quote
Old 08-28-2006, 02:37 AM   #8
Kinda seems that hes just stringing together names of car parts that hes heard somewhere in life, to try and make something make sense.
Old 08-28-2006, 03:20 AM   #9
flashgordon
thanks for the flame!!!
If you didn't under stand what i was trying to say then you could have just asked!
my car will not start,..... how hard is that to under stand......even if your not machanicly minded!
Sorry, i thought that "repair and maintenance" was just that!
and even thow i'm not the best speller on this sight do not mean i'm stuped!
there has got to be real machanices, that can understand what i'm talking about!
newjocker and torinoman80. I'm not asking how to install bad ass stiero or neon light sooooooooooooo you can't help me
there's got to be more knowledge then you two jockers!
And just for the record, it.. (My 93 Honda Civic) sat, safely in my garage, for 6 1/2years cust there was no need for it!
I told my son that i would fix it up for him if he when to collage!
he's going and i'm trying to fix it!
Is that so hard to understand......evan if i can't spell worth shit!
Old 08-28-2006, 03:23 AM   #10
Sorrry, i thought that "repair and maintenance" was just that!
and even thow i'm not the best speller on this sight disn't mean i';m stuped!
And just for the record, it.. (My 93 Honda Civic) sat safely in my garage for 6 1/2years cust there was no need for it!
Son's going to colage.....ya know school!!!! and he needs a good reliable car!
is that so hard to understand......evan if i can't spell worth shit?!
Maybe thats why its not starting...
Old 08-28-2006, 05:32 AM   #11
flashgordon
I drain all the bad gas out of the gas tank when i replace the fuel pump so the 6 1/2 year old gas is not the problem
Fuel pressure is good. no injector pulse(computer not sending the signal to fire the injectors)
Eng.will start with carb spray in the intake!!!
Old 08-28-2006, 12:00 PM   #12
Replacing the all the fuel in the tank and and replacing the fuel pump,.. shoud have fix the 6year sleep
After 6 years, I would imagine the battery would be drained, and the oil would be gunked up and in need of a drain if not some pro service.
Old 08-28-2006, 02:01 PM   #13
flashgordon
Pro service is what i"m trying to avoid(taking it to the deal,that is!) and is why i spent over $100.00 for a FSM(Factory Service Manual) or honda service manual if you will......ok, manual will take several days and evan with it i could still us some help!
replace oil. fuel, air,and fuel filter while i was repacing the fuel pump.
This is what i'm looking for!
neather on of us know the answer but, bouncing ideas off of each ather is what keep me from missing something simple and stuped....like checking a fuses and yes i did check them all.......all of them that i now of that is!
one fuse block under the hood, passanger side, and the one under the steering collome!
allso have checked the conector on the ECM for crosion and thay are clean!
I can't help but think that when that fork lift arm when thru the the hood, i broke a wire but the only wires that i can find bad, or the one's on the speed control?
Old 08-28-2006, 02:17 PM   #14
1. I hate to type ANYTHING that may be misconstrued as agreeing with newyorker, but... Your lack of communication skills makes it extremely hard to understand what it is you're trying to tell us.
2. Don't waste your time arguing with newyorker. He is an idiot of the highest order. His idea of working on a car is finding the fuel filler at the gas station. He is entirely devoid of a clue.
3. Finally.
Pro service is what i"m trying to avoid...
As long as you don't want "pro service", that means I can now excuse myself from this thread. Dont forget. Simply ignore newyorker. He will eventually go away.
Old 08-28-2006, 04:12 PM   #15
flashgordon
3. Finally.
Please dont!
what i "meant by avoiding pro service" is I don't want to take it to a honda dealer, 100 miles a way. If some one could give me ides to guide me to the solution,,,,help me, to fix my honda, at my home.
taking it to the deal may be what i will have to do in the end but i got to try first.
and any help from any body on this form would be grately aprieseated!!!!!!
