Old 04-20-2005, 10:05 PM   #1
zdrepaul
92 Accord slow acceleration
there's a 2 to 3 sec delay from idle to 2500rpm when i hit accelerator. plugs ok, fuel pump/injectors/filter ok, wires/cap/rotor ok, timing seems to be ok. from an idle stop in drive, it takes a long time to get to ~2500rpm then it jerks a little, then runs fine the rest of the rpm spectrum. it does the same thing in park. during the 2 to 3 sec delay it sounds like it's not getting any fuel but lots of air or timing is not advancing fast enough to keep up with the position of the throttle. what's really weird is that it only does it at lower rpms. any ideas? thank you.
zdrepaul is offline   Reply With Quote
Old 04-23-2005, 10:15 PM   #2
FordFromHell351
FordFromHell351's Avatar
Check your mass air flow sensor. Its either that or youve just got a weak engine.
Old 04-25-2005, 06:36 AM   #3
bigv8
i think i got a good idea why the car its slow....its shit. Its got no power, no displacement and overall is a granny car. Cars like that are not meant to go fast. They are designed to carry little people around cities, not the quater mile. Get a real car...at least 6 cylinders....in a V.
bigv8 is offline   Reply With Quote
Old 04-25-2005, 09:10 PM   #4
thunderbird1100
CF dB-o-holic
Would you call the old Ford 255 4.2L V8 a 'real' engine? Because it makes less power stock than his Honda 132 2.2L I4.
1990 Honda Accord LX Sedan
Mileage Ticker: 232,400 Miles
Stereo Mods: Coming soon...
~Blow your mind~
thunderbird1100 is offline   Reply With Quote
Old 04-25-2005, 11:45 PM   #5
Accord_Man
Accord_Man's Avatar
So you're saying that the Supra TT isn't a real car......... it rocks
Some people don't have enough money to pay for a V8 car, or enough money to pay for its poor gas mileage.
Accord_Man is offline   Reply With Quote
Old 04-25-2005, 11:54 PM   #6
Accord_Man
Accord_Man's Avatar
If all you're gonna do is bad mouth smart, economic, durable Japanese cars, then you might want to try the DOMESTIC section of this forum.
Old 04-28-2005, 01:09 PM   #7
Are you saying that an R34 Skyline or a Supra RZ are crap? Cars don't need to have displacement to go fast or at least feel fast.
Old 04-28-2005, 10:50 PM   #8
JDMprelude92
What the problem is, is that your clutch is slipping and you need to replace it. Yould have to probobly replace the clutch and pressure plate and depending on how bad it realy is you might have to replace the throw out bearing and the fly wheel.
Tuner
JDMprelude92 is offline   Reply With Quote
Old 05-12-2005, 05:12 AM   #9
ztek88
Or if its an auto have your tranny fluid checked.Sometimes low fluid pressure will delay shifts. .. remember more air more power.
ztek88 is offline   Reply With Quote
Old 05-12-2005, 05:33 AM   #10
Vlad
So the Evo is crap too huh...cuz its 4 cylinder? Not a real car?
Vlad is offline   Reply With Quote
Old 05-12-2005, 05:53 AM   #11
SubaruCorsi
And don't forget the STi.....
SubaruCorsi is offline   Reply With Quote
Old 05-12-2005, 11:51 PM   #12
srober32
srober32's Avatar
Lets not forget the ho4's in the Porsches. Or we could go a different route with the flaming...semi's and medium duty trucks put out more torque and hp than most v8's...with i6's or i8's, go figure.
When replacing your altenator, make sure your battery is fully charged.
srober32 is offline   Reply With Quote
Old 05-12-2005, 11:55 PM   #13
^^Even more power than quite a few V12s, for that matter.
I have had a similar problem with my 94 Accord EX. Not so much the lack of response, but the sudden "jerks" with no change in throttle position. It'll get to about 2500 rpm too and suddenly accelerate faster. As it isn't really a problem for me I've never worried about it.
Old 05-13-2005, 12:10 AM   #14
srober32
srober32's Avatar
Back on topic, check the tranny, sounds like the o/d may be acting up (popping on and off).
Old 05-13-2005, 12:23 AM   #15
C c C
C c C's Avatar
it may be your carb.. run your car on almost complete empty and dump some carb cleaner in ur tank.. its worth a shot
C c C is offline   Reply With Quote
