Old 05-21-2005, 11:38 PM   #1
CarEXPERT
Manual Transision
HOw do you check, fill, and change a MANUAL transmission FLUID?
Old 05-21-2005, 11:45 PM   #2
DodgeRida67
DodgeRida67's Avatar
Generally speaking you have a drain plug obviously to drain the fluid or gear oil and you have a fill plug obviously used to add fluid or gear oil. Usually when the gear oil or fluid is level with the fill plug, it's full.
DodgeRida67 is offline   Reply With Quote
Old 05-21-2005, 11:59 PM   #3
CarEXPERT
So there is a drain plug at the bottom and a FILL PLUG also at the bottom? Isnt it hard to fill like that?
And for the check fluid, do you check with the drain plug or fill plug or is there a third plug? Thanks DR!
Old 05-22-2005, 12:20 AM   #4
DodgeRida67
I never said that. Fill plug is usually half way to upward 3/4s of the tranny. Drain plug is usually at or very near the bottem.
You check it with the fill plug. Like I already said, when the fluid or gear oil is level with the fill plug it's full.
Old 05-22-2005, 12:34 AM   #5
CarEXPERT
So the fill plug is facing upwards or sidewards? I mean is the fill hole facing upwards or side?
Old 05-22-2005, 12:35 AM   #6
DodgeRida67
The fill plug is on the side of the transmission.
Old 05-22-2005, 12:47 AM   #7
CarEXPERT
Thank you dodge. So when you check the fluid level, does the engine need to be running or does it need to be hot but at opperating temperature.
Old 05-22-2005, 12:53 AM   #8
DodgeRida67
Check it off and cold.
Old 05-22-2005, 12:58 AM   #9
CarEXPERT
same for automatic?
Old 05-22-2005, 01:00 AM   #10
DodgeRida67
same for automatic?
No. Autos usually are checked when at normal operating temp. in either P or N.
Old 05-24-2005, 01:04 AM   #11
In my 323, you have to take out the speedometer gear adapter, and it has marks on it. Its on the top of the tranny, and has a cable coming from it. Careful though, I broke the flimsy aluminum flange holding it down last time i checked mine.
Most cars don't use this method though, so check your manual.
