Old 07-30-2005, 03:56 PM   #16
DodgeRida67
DodgeRida67's Avatar
Overdrive is the gas saving gear though correct?
Overdrive is any gear with a ratio less than 1:1 so that the output shaft is turning faster than the input.
DodgeRida67 is offline   Reply With Quote
Old 07-30-2005, 04:11 PM   #17
Well i know that but does it really improve gas mileage a little if you have OD?
Old 07-30-2005, 08:32 PM   #18
The highest gear will always be the most fuel efficient, but any gear below 1:1 ratio is an OD gear. If you have 26 gears, and ten gears below 1:1, then all ten are OD, but yes, 26th gear is the most fuel efficient. WHy is this so complicated???
Old 07-31-2005, 12:29 AM   #19
It only improves gas mileage becaus you are at a lower rpm and therefor using less gas.
