Old 07-27-2005, 01:22 AM   #1
PontiacBird
paintjob!?!?!?!?!?!?
how much do you all think it would be to paint my 91 firebird, i would like it silver with metallic blue rally stripes.
the body is in fine shape, no body work needed.
thanks!
dave
PontiacBird is offline   Reply With Quote
Old 07-27-2005, 01:23 AM   #2
thunderbird1100
CF dB-o-holic
thanks!
dave
From a good reputable place, probably anywhere from $600-$1000.
1990 Honda Accord LX Sedan
Mileage Ticker: 232,400 Miles
Stereo Mods: Coming soon...
~Blow your mind~
Old 07-27-2005, 05:50 PM   #3
Vlad
More towards the 1k and up than the 600. I heard just the materials for a good paint job run 500-600 bucks, so if your getting a paintjob for that much, obviously they are using inferior paint.
Vlad is offline   Reply With Quote
Old 07-27-2005, 07:37 PM   #4
The materials bill for teh repaint on my Fiat 9which i did myself) was about $500. When I had a shop of my own and was buying the materials at fleet prices, it was about that for enough to do a larger car. With inflation for teh last few years factored in, figure fleet cost for the materials at about 800 or so for a firebird for OK, but not high end, paint. Add labor. I used to do complete repaints in one color for $1800 using PPG urethanes. That was 10 years ago.
Prep is everything. even if it doesn't need bodywork, it will need to have the surface prepped properly, which included removing all the trim and the like, preping the door jambs, hood and trunk jambs, etc, thorough sanding, priming, block sanding the primer to make it level, final prime, scuffing, and paint (in your case, two colors PLUS the metallic should be under a clearcoat). To do it right should take at least a week, if not two, at a normal shop.
