Old 07-27-2005, 07:54 PM   #1
sweetlady
01' chevy impala veh shuts of when started & rpm gage goes up & down
I have noticed lately when i start my vehicle it shuts off , the only way to keep it running is pressing on the gas & let it run for a while , but then my rpm gage goes up & down between 0 and 1 rpm and makes my engine shake until i press the gas then it stops but once i release the gas pedal the rpm gage goes up & down again. I have noticed that only when the car is on low fuel thats when it shuts off when i start it. but when it has a half a tank or more of fuel it starts and stays on but the rpm gage still goes up and down & the engine makes a noise and shakes the car. i dont know what it is, can someone help me please?.. I have gotten a new fuel filter on the veh but problem still occurs help help
sweetlady is offline   Reply With Quote
Old 07-28-2005, 12:00 AM   #2
97Talonchik
discombobulated
97Talonchik's Avatar
Have you cleaned your injectors?
Old 07-30-2005, 10:21 PM   #3
sweetlady
I just had my impala worked on this friday , & the diagnostic sys pulled up that it was my idle control valve. which only cost about $35.00. that is where your rpm idle is lower or higher than suppose to be. and being that the idle control valve was going bad & the rpm was lower than suppose to be it wasnt pushing thru enough air in my engine to keep it started . so that is why when i started my veh it just kept shutting off & it was misting really bad. but now the car is running better than ever.
