Old 08-15-2005, 04:24 PM   #1
cfjackson
1979 Dodge 440 Motor Home(appollo)
MY MOTORHOME TRIES TO START BUT ACTS LIKE IT IS ADVANCED, WON'T QUITE KEEP RUNNING.
MODULE WAS REPLACE(IGNITION) AND DISTRIBUTOR CAP AND ROTOR.
CARB SEEMS FINE. ANY IDEAS?
ARE THERE OTHER TIMING CONSIDERATIONS, TDC APPEARS OK
cfjackson is offline   Reply With Quote
Old 08-15-2005, 11:31 PM   #2
adamc44
CF Freak
adamc44's Avatar
does it have the lean burn system still???
AMERICA: LOVE IT OR LEAVE IT
Old 08-15-2005, 11:55 PM   #3
adamc44
CF Freak
adamc44's Avatar
i had to do a little research, but i knew that i had read somewhere that factory chrysler timing chains and gears were junk...
This came from a low mileage engine that ran great, so everything is good to go, right? Wrong. Note the missing teeth and cracks in the cheesy nylon coating, once enough of these break off it will slip or come undone altogether, either way you're screwed. So cough up the $25 and do it
