Old 08-22-2005, 05:50 PM   #1
HUEXB18C
Exclamation Sputtering Gsr
I HAVE A JDM GSR SWAP IN MY 92 HATCH BACK
I THINK I HAVE A SHORT BUT I HAVE NO IDEA WERER TO START
LOOKING,WHEN UNDER W.O.T."WIDE OPEN THROTTLE"
IT SPUTTERS AND MY RPM GAUGE JUMPS AROUND
I THOUGHT IT WAS MY FUEL PUMP BUT WOULD THAT MAKE MY
RPM GAUGE JUMP AROUND,SOME PLEASE HELP ME
HUEXB18C is offline   Reply With Quote
Old 08-22-2005, 06:11 PM   #2
glagon1979
daddy x3
glagon1979's Avatar
when u say "jumping around", does the rpm jump around like its hitting a rev limiter before it should? is you computer throwing codes? sounds like a problem i had with my winter beater. it ended up being the distributor.
glagon1979 is offline   Reply With Quote
Old 08-22-2005, 09:01 PM   #3
HUEXB18C
Exclamation
Kinda Like That But Its Only When Its Under W.o.t Do U Think Its The Dist,or The Ignitor?AND THE ECU ISNT THROWING ANY CODES
Old 08-22-2005, 09:29 PM   #4
glagon1979
daddy x3
glagon1979's Avatar
[quote=HUEXB18C]Kinda Like That But Its Only When Its Under W.o.t Do U Think Its The Dist,or The Ignitor?AND THE ECU ISNT THROWING ANY CODES[/QUOTE
the ignitor is in the distributor
Old 08-22-2005, 09:37 PM   #5
HUEXB18C
Exclamation
But If The Dist,is Bad Would That Make My Fuel Relay Go Out
Old 08-22-2005, 09:45 PM   #6
glagon1979
daddy x3
glagon1979's Avatar
i never said it was the dist, i was just giving ideas. usually if the relay was bad it wouldnt run at all.
Old 08-22-2005, 09:53 PM   #7
HUEXB18C
Exclamation
I' Know U Were Giving Suggestion,
I Replaced The Relay,it Ran Ok But Still Sputtered At W.o.t
And Now It Has Problems Starting And When It Does
It Sputters Bad,
Old 08-22-2005, 10:15 PM   #8
HUEXB18C
Exclamation
Or Do U Think It Could Be A Bad Ground
