Old 08-31-2005, 02:10 AM   #1
1/4Drag_05
99 Sienna Le Trunk problem
Ok i hav a 99 Toyota Sienna Le. The lock on the back for the trunk isn't working, and i can't even get the key in. Also, i can't unlock it from the inside or with the key. It's stuck closed, and it's friggin annoying. Any suggestions?
1/4Drag_05 is offline   Reply With Quote
Old 08-31-2005, 02:38 AM   #2
Macc
Try pushing down or pulling up on it when you use the key or inside trunk release. If that doesn't work try firmly banging down on the trunk several times near where the lock mechanism is (also try this when using the key and release). Try squirting some graphite into the key hole. If all else fails, modern cars have an emergency release inside of the trunk case a child gets locked inside. You should be be able to remove the back seat and gain access to this (even if its only with a stick or something). If you're successful then you should be able to determine the problem (It might just need some oil). Good Luck!
Macc is offline   Reply With Quote
Old 08-31-2005, 04:35 AM   #3
GonnaDie4TheGov
CF's Only Jersey Boy
GonnaDie4TheGov's Avatar
Your hydros are prob shot. Jsut pull up when you turn the key or hit the latch.
2001 Honda K-1 Accord Attack
GonnaDie4TheGov is offline   Reply With Quote
Old 08-31-2005, 05:11 AM   #4
Tech_N9ne
Tech_N9ne's Avatar
...plasma cutter...lol
Tech_N9ne is offline   Reply With Quote
