Old 09-23-2005, 08:56 PM   #1
xt3rri0r
Fuel Saver
I seen this product on TV and it suppose to save gas and improve horsepower. Has anyone used this before? Click Here
xt3rri0r is offline   Reply With Quote
Old 09-23-2005, 09:03 PM   #2
DON"T BUY IT, It is a scam, the thing actually reduces gas mileage and performance a little bit
Just read September's Popular Mechanics and see the truth
Old 09-23-2005, 10:05 PM   #3
Yeah that's a good article, kinda scary though, the person driving along beside you might have something like that that could just suddenly catch on fire
Old 09-25-2005, 03:02 AM   #4
xt3rri0r
ahh i see i won't purchase that thanks
Old 12-06-2005, 02:19 PM   #5
mcrew
There are several ways you need learn to use when it comes to increasing fuel mileage of your car.
1) Electronic Ignition Systems
2) Fuel Catalysts
3) Free-Flow Air Filters
4) Tire Inflation
5) Other Products
This class of accessories really applies to the older vehicles that still run on the traditional contact breaker systems. Those who wish to keep vintage vehicles on the road will find that fitting a contact-less ignition system is the way to go.
Although it is not strictly a fuel-saving device, it ensures that the vehicle stays in tune and retains the fuel economy that a freshly-installed contact breaker system would provide. Minimal maintenance and consistent fuel economy result in increased gas mileage and fuel savings of your car.
Fuel Catalysts
Due to the recent increases in fuel prices, we’ve been getting a lot of response on this method. Suffice to say, fuel catalysts are elements you would put on your gas tank to speeds up the combustion process. This in the end will improve your car fuel efficiency and improve your gas mileage.
Some catalysts can simply be dropped into the fuel tank, while there are some that require to be installed somewhere along the fuel line, between the tank and engine.
A catalyst is a chemical, substance or compound that accelerates a chemical reaction. But it remains unchanged and is not used up during the process. When a catalyst is installed along the fuel system, it speeds up the combustion process, rendering it more complete, and allows for the complete release of energy from fuel combusted.
Installation is pretty straightforward and one-off affair. You’ll recover your initial investment spent on catalyst within a short period of time, from the increased gas mileage savings of your car. Catalysts may also be used for the entire life of the vehicle, and are transferable from one vehicle to another.
The more popular fuel catalysts are made of compounds of tin and other precious metals, but the actual formulation remains a commercial secret. They claim to promote smoother engine operation, cleaner exhaust emissions and can increase fuel mileage savings of up to 8%.
Grouped in the same category as the contactless ignition systems, free-flow air filters offer no gas mileage savings over a brand new item. Most filter elements are washable, and can be used over thousands of kilometers. After that, you may need to replace the air filter on regularly basis. According to the report on Gas Mileage Tactics, studies have shown that replacing a clogged air filter can improve the mileage that you get with your car as much as 10%.
Tire Inflation
Oxygen in compressed air permeates through the wall of the tire, and inflation pressure is reduced over time. In the process, oxygen oxidizes the rubber compounds in the tire, causing under inflation and deteriorated rubber. Dry nitrogen will can prevent auto-ignition; it will not corrode rims, and can will help the tire to run cooler, resulting in longer tread life. So tire replacement costs go down.
Other Products
Fuel and lubricating oil additives claim to lower internal engine friction drag and improve combustion respectively. Some may work and some may fail considerably. It is important that the device fitted or the additive used does not destroy the catalytic converter. Neither it should void your new vehicle warranty.
At last, increasing your car gas mileage and doing every bit to save money on gas does not require rocket science to understand its importance. No doubt there are no products ever produced by man that could save you thousands of dollars in gas money, but every little penny you would save from every drop of gas goes a long way.
A little step each day will lead to success so you should really start now. Get all the tips and techniques and learn how to get extra mileage when you subscribe to ExtraGasMileage newsletters at Gas Mileage Tactics Good luck in your quest for extra gas mileage!
mcrew is offline   Reply With Quote
Old 12-06-2005, 04:32 PM   #6
http://www.popularmechanics.com/auto...y/1802932.html
Old 12-07-2005, 12:47 AM   #7
Vlad
That was a good read. Thanks for the link chris.
What I can't get is why don't these people get in trouble for falsely advertising a product? They are saying it will do all this stuff, but it really does the opposite, and they can get away with it?
Vlad is offline   Reply With Quote
Old 12-07-2005, 02:13 AM   #8
It will probably say something like, "Up to 300% better fuel economy"...But I find that a scam too, and it should be proven to provide what it claims...
