Old 03-02-2004, 07:30 PM   #46
snoopewite
The 1st CF Entrepreneur
snoopewite's Avatar
That's two flames in a row
This signature is in memory of vwhobo 03-26-2003 - 04-27-2004
The vwhobo fan club lives on for as long as his e-spirit lurks around these forums.
Late vwhobo fan club members - R34RB30DETTV, SuperJew, Cliffy, STiMan, Satty101, Integra_LS, Karburator, DodgeRida67, Bubba, Importluva and snoopewite - instigator of the unofficial vwhobo fan club
snoopewite is offline   Reply With Quote
Old 03-02-2004, 07:43 PM   #47
Originally Posted by AnotherOne
I am 100% behind MauditOstie...
That's all I have to say... and all that without introducing myself.
One more (thanks to snoopewite!)
Old 03-02-2004, 07:50 PM   #48
snoopewite
snoopewite's Avatar
Here's another one for AnotherOne
Old 03-02-2004, 07:51 PM   #49
AnotherOne
Originally Posted by snoopewite
Do you know that from experience? Have you been let down in the past?
Yes, you're right. I know that from experience. It was when I was kid, before I made love to a women for the first time. I realized then that the size is not important. It is to the way you use it that makes the difference.
AnotherOne is offline   Reply With Quote
Old 03-02-2004, 08:04 PM   #50
AnotherOne
You took the picture from your own souvenirs... ?
Old 03-02-2004, 08:31 PM   #51
snoopewite
snoopewite's Avatar
Nope... but I can't post anything from my souvenirs because too many risque pictures of 'babes' in these forums are frowned upon.
Old 03-02-2004, 08:31 PM   #52
I wasn't even aware they made a Tercel in 1999.
Old 03-02-2004, 08:39 PM   #53
AnotherOne
It seems that everybody in this forum took the same course "How to be self imbued in 10 step."
Old 03-02-2004, 08:57 PM   #54
snoopewite
snoopewite's Avatar
Maybe you should take a course in typing out messages correctly for these forums? "10 step"? What happened to the s?
As for being self-imbued, I remain humble with an annual salary of less than $100, 000 and an I.Q of less than 160
Old 03-02-2004, 09:02 PM   #55
Maybe we can get back to the topic of helping out Maudi?
Old 03-02-2004, 09:02 PM   #56
cmeseadoin
CF Freak
Look at all this fun being had all because I started it. I am proud to be a sh*tstirrer.
Anotherone, would you like an offline picture? I'd hate to make you wet. LMAO!!!!!!!
2006 Mazdaspeed6, 2002 Pontiac Trans AM Ram Air WS-6, 1996 Jeep Cherokee Sport 4x4, 2002 Durango 5.9 R/T, 1995 Jeep Cherokee Sport 4x4, 1994 Ford Taurus SHO 3.2L, 1976 Buick 225 Limited, 1992 Miata, 2008 Miata.
Other toys: 2003 Honda Superhawk 996 sportbike, 2007 Suzuki M109R cruiser, 2006 Kawasaki KLR 650, 1996 and 1997 Sea Doo GSX limited watercraft.
cmeseadoin is offline   Reply With Quote
Old 03-02-2004, 09:08 PM   #57
snoopewite
snoopewite's Avatar
Be careful not to step on BavarianWheels toes
Old 03-02-2004, 09:20 PM   #58
cmeseadoin
CF Freak
Ok, back to the topic
Ok, now that we had our all day fun, , let's see what we can do for Maudi......
In his last post, he indicated that basically fuel and ignition seemed to be fine. All spark plug wires were checked and the fuel pump was working. That being the case, I would still advise you to check the fuel pressure using a test gauge. You're fuel pump could be running but the pressure getting up past the regulator to the rail could be impeeded. Your pressure regulator "could" be bad.
Remember the follow components that are necessary for a 4 stroke(4cycle) engine that runs: Intake(presence of fuel/air getting into the combustion chamber), compression(req'd to create a volatile mixture out of the gas/fuel mixture), power (pressence of ignition to the spark plugs) and exhaust (relief of combustion bi-products). If you have fuel,compression, and ignition in the absence of an intrisically bad engine via wear or damage as well as a sensor problem/computer problem inhibiting one of the above mentioned items, your engine will fire and run. So look at it simplistically.
Verify that fuel is getting to the plugs by spinning the engine over for a few and then pulling out several plugs and look for wetness. Check the ignition for spark at the plugs which you say you've done. If you are getting fuel and you are getting spark to your knowledge, you may have a more complicate issue. I suggest hooking up the good ole' OBD II data link and seeing if there are any codes such as Crank sensor problems or anything like that which could cause the computer to not fire the ignition system at the right times. Also, you mentioned you did verify the fuel pump running and the ignition spark......you may have a situation where the fuel injectors are not being pulse or the pulse widths are not correct. If you smell the PCM then you MAY have a computer issue and I'd hook up OBD II and find out if you see anything there.
Without having it in front of me, I am temporarily out of ideas.....hope that helps after I was being mean earlier. I was just in a fiesty mood and now that you will give us technical details, I will try and help!
Old 03-02-2004, 11:15 PM   #59
SuperJew
I like pie.
SuperJew's Avatar
wow...a 4 page argument...
think this is a new CF record?
CF's Resident Pimp Slapper
Pimp Slap Count (as of 30 May 2004): 34
SuperJew is offline   Reply With Quote
Old 03-02-2004, 11:17 PM   #60
And I wasn't even involved in most of it. By the way, on my computer it's only two pages. You can change that on the User CP.
