Old 08-31-2003, 01:29 AM   #1
snoopewite
The 1st CF Entrepreneur
snoopewite's Avatar
Lots Of Questions
All these questions have just built up over time -
Whatís the insurance grouping system like in America?
Are these things that are sometimes with attachments just to let people know that there should be an image there? arrow [c/imgs]
What are POS cars?
How are pony cars different to muscle cars?
Whatís the name for twin turbos that kick in at the same time that are opposed to sequential turbos? Are stacked turbos the same as sequential turbos?
What does N/T mean? Itís something to do with bracket racing isnít it?
What does all motor mean?
Whatís a car dial-in i.e. a 14.50 dial-in?
Aren't there any decent aftermarket gearboxes for the 300 ZX?
Whatís a whisper lid?
What are sodium valves for lower compression ratios all about?
What does a 2-bolt block and a 4-bolt block mean?
Roughly how much does labour cost to have the catalytic converter taken out of an exhaust, or canít it possibly be taken out without replacing the whole section of pipe?
Very roughly, how much does anyone think the following would cost for labour to be installed into a MK4 Supra single turbo -
Greddy T88, downpipe, turbo header, wastegate and air intake system.
Stronger fuel system, fuel rail, 850cc injectors, twin pumps, wiring, relays, braided large line, fuel filtration, fittings etc.
AEM EMS Ė 3 bar map sensor.
HKS twin power ignition.
What's quaiffe?
Any answers will be appreciated wink
This signature is in memory of vwhobo 03-26-2003 - 04-27-2004
The vwhobo fan club lives on for as long as his e-spirit lurks around these forums.
Late vwhobo fan club members - R34RB30DETTV, SuperJew, Cliffy, STiMan, Satty101, Integra_LS, Karburator, DodgeRida67, Bubba, Importluva and snoopewite - instigator of the unofficial vwhobo fan club
snoopewite is offline   Reply With Quote
Old 08-31-2003, 02:07 AM   #2
57ock
Re: Lots Of Questions
Originally Posted by snoopewite
All these questions have just built up over time: -
What are POS cars? Piece Of Shit?
What’s the name for twin turbos that kick in at the same time that are opposed to sequential turbos? Are stacked turbos the same as sequential turbos? stacked. never heard of it.
What does all motor mean? All motor means All motor. No turbo, No S/C and no NOS. Just pure engine HP
What’s a car dial-in i.e. a 14.50 dial-in? If you dial in a 14.5 1/4 mile and you do a 14.45 1/4. It means you broke out of your dial in. So the other car wins. Unless he breaks out too. The idea is to get as close to your dial in as possible without going under it.
Aren't there any decent aftermarket gearboxes for the 300 ZX? Yes. Nismo has them.
Roughly how much does labour cost to have the catalytic converter taken out of an exhaust, or can’t it possibly be taken out without replacing the whole section of pipe? catalytic converter are easy to knock out. Just need a broom handle I have a 3" pipe thru the centre of my"racing" cat. Makes a good power difference.
Very roughly, how much does anyone think the following would cost for labour to be installed into a MK4 Supra single turbo: -
Stronger fuel system, fuel rail, 850cc injectors, twin pumps, wiring, relays, braided large line, fuel filtration, fittings etc. Shit loads
AEM EMS – 3 bar map sensor. That maps the air mass. It does the same job as a air flow meter, but is able to be used as high boost levels where a afm will max out. AFM measures the flow of the air, not the mass
HKS twin power ignition. The problem with running high boost levels is, you can blow the spark plug spark out. So you need a device to create a stronger spark.
www.car-forums.com
57ock is offline   Reply With Quote
Old 08-31-2003, 11:39 AM   #3
snoopewite
snoopewite's Avatar
Thanks 57ock, I thought youíd be able to help )
That leaves the following questions -
? Whatís the insurance grouping system like in America?
? Are these things that are sometimes with attachments just to let people know that there should be an image there? arrow [c/imgs]
? What are POS cars?
? How are pony cars different to muscle cars?
? Whatís the name for twin turbos that kick in at the same time that are opposed to sequential turbos? Are stacked turbos the same as sequential turbos?
? What does N/T mean? Itís something to do with bracket racing isnít it?
? Whatís a whisper lid?
? What are sodium valves for lower compression ratios all about?
? What does a 2-bolt block and a 4-bolt block mean?
? Very roughly, how much does anyone think the following would cost for labour to be installed into a MK4 Supra single turbo -
? Whatís quaiffe?
Old 08-31-2003, 12:00 PM   #4
That leaves the following questions: -
:?: Whatís the insurance grouping system like in America?
:?: Are these things that are sometimes with attachments just to let people know that there should be an image there? :arrow: [c/imgs]
:?: What are POS cars?
:?: How are pony cars different to muscle cars?
:?: Whatís the name for twin turbos that kick in at the same time that are opposed to sequential turbos? Are stacked turbos the same as sequential turbos?
:?: What does N/T mean? Itís something to do with bracket racing isnít it?
:?: Whatís a whisper lid?
:?: What are sodium valves for lower compression ratios all about?
:?: What does a 2-bolt block and a 4-bolt block mean?
:?: Very roughly, how much does anyone think the following would cost for labour to be installed into a MK4 Supra single turbo: -
:?: Whatís quaiffe?
1. There is no real "system" in the states. Unlike the UK it's more of a magic potion. It varies state to state, company to company, even city to city.
2. Beats me.
3. Piece Of Shit.
4. A "pony car" is a class of car started in late "63 by the Barracuda and made popular in '64 by the Mustang (hence the name). Basically they're sporty cars based on then popular US economy cars in the 108" wheelbase class. Muscle cars are slightly larger with a wheelbase in the 112" area. Honestly the two groups have more in common than different.
5. Turbos, whe don't need no stinking turbos.
6. In all my years of bracket racing N/T means nothing to me.
7. ???
8. Sodium valve don't lower compression. Sodium valves have hollow valve stems with liquid sodium inside which helps to dissapate heat better.
9. Used mostly for small block Chevy's when refering to how the main bearing caps are attached.
10. Too freaking much.
11. Quaiffe is a torque biasing differential.
Snoope, how about fewer questions, more often. See ya.
Old 08-31-2003, 01:41 PM   #5
57ock
snoopewite, I'm just very slack
www.car-forums.com
Old 08-31-2003, 04:05 PM   #6
snoopewite
snoopewite's Avatar
vwhobo wrote -
"10. Too freaking much."
Would it be more than $10, 000?
vwhobo wrote -
"Snoope, how about fewer questions, more often. See ya."
That sounds like a good idea... It's not good to bottle things up is it )
Thanks for the reply vwhobo thumbs
57ock wrote -
"snoopewite, I'm just very slack"
Now we know that's not true don't we 8)
Old 09-01-2003, 12:43 AM   #7
57ock
Greddy T88 33D $3200
downpipe(Dump Pipe) $550
turbo header $1050
wastegate $650 for TurboSmart 42mm
air intake system. (New pipes to air filter) 400. (includes K&N airfilter)
Stronger fuel system. Malpassi $250 Audi Motorsports Fuel pump. $300
Custom fuel rail. $200
850cc injectors, $400 each
wiring. No need for major rewiring.
relays, Nop
braided large line. Large? U need new braided oil lines to and from the turbo. There 100 bucks for the kit. Water lines can be high heat rubber. Just as long as they don't touch the exhaust housing of the turbo. 40 bucks
fuel filtration, Stock system is fine
fittings. Few brackets will be needed. 40bucks?
Thats all in Australian Dollars.
www.car-forums.com
Old 09-01-2003, 12:46 AM   #8
57ock
Btw, there are 3 types of T88
T88 33D
T88 34D
T88H 34D
www.car-forums.com
Old 09-01-2003, 02:03 AM   #9
Machine
I've known a few 34Ds...Ah, thank you...
"All the Power in the World resides in the Eyes..."
Machine is offline   Reply With Quote
Old 09-01-2003, 11:35 PM   #10
snoopewite
snoopewite's Avatar
57ock wrote -
"Greddy T88 33D $3200
turbo header $1050
relays, Nop
Thats all in Australian Dollars."
Thanks for taking the time to do that 57ock thumbs
Similar Threads
Thread Thread Starter Forum Replies Last Post
2 Quick Questions snoopewite Off Topic 5 02-04-2004 03:09 AM
Quick question(s) 84_Jetta_GLi Repairs & Maintenance 1 09-06-2003 01:20 PM
Questions about my 1981 Corvette Domestic Cars 5 02-12-2003 12:13 PM
