Old 11-12-2005, 04:09 PM   #1
Grannie2
'91 Chevy Lumnia Euro--Brake switch
My Lumina has 174,000 miles on it. I keep it in good runing order. My problem is that it can't decide whether it wants to stay in overdrive or not. I have taken it to my mechanic and he sent me to a transmission specialist to weed out any trans. problem. He told me the transmission was in excellent condition, that it was a brake switch problem, it was either loose or bad. Has anyone ever known the brake switch to give this kind of problem?
Grannie2 is offline   Reply With Quote
Old 11-12-2005, 05:23 PM   #2
Yes, because at highway speed, one of the funtions of the brake switch is to unlock the torque converter if the brakes are applied. Try this test. Drive at a speed that this problem shows itself, probably around 45+ mph on a mostly straight level road. Engage your cruise control. If the cruise stays engaged and the transmission still hunts it is most likely NOT the brake switch. However, if the transmission hunts and drops the cruise simultaneously it most likely IS the switch.
Old 12-08-2005, 04:47 PM   #3
Grannie2
'91 Chevy Lumnia Euro--Brake switch or what
Well, I had my brake switch changed (off brand not manuf. part). It seemed to work well for about a week and it slowly started to reoccur and now does it about the same amount of times as it did before. It is at the dealer to check the problem. Dealer says it is not doing it with him. Now what?
