Old 12-14-2005, 01:17 AM   #1
Godlaus
UnFedFat in Disguise
Godlaus's Avatar
Fwd
Can someone please point out ONE performance advantage that FWD has over RWD? I'm completely blank....
On a track, straight, anything. Name one advantage.
I am everything you want to be
Old 12-14-2005, 02:12 AM   #2
windsonian
Dodger65's weirdo
windsonian's Avatar
I'd reckon it'd be a little better accelerating out of corners in the wet ... no? sure, you'd still get wheel slip, but you'd be less likely to lose control of the car.
Just a guess anyway..
Old 12-14-2005, 02:52 AM   #3
pik_d
CF not-so-Freak
pik_d's Avatar
i cant read.
pik_d is offline   Reply With Quote
Old 12-14-2005, 02:56 AM   #4
Bino
Written Off
Originally Posted by pik_d
possibly weight shifting to the rear under hard acceleration = more traction for rear tires.
why not ask this question to nascar/formula 1/le mans teams? maybe they have an answer? but so far as i know, under 300hp, there's no real difference in preformance.
tire wear may also be of importance for endurance races of cars with high horsepower (let's just say 300hp is "high"). being the wheels that both turn the car and drive the car, the front wheels would have more tirewear in a FWD car by far. with a RWD car tire wear is more evenly distributed, and therefore it would take longer before a new set of tires is needed.
You perfectly missed the the point of this post.
Build 'em Light and Wind 'em Tight.
Bino is offline   Reply With Quote
Old 12-14-2005, 03:04 AM   #5
pik_d
CF not-so-Freak
pik_d's Avatar
oh crap. i completely read that wrong... oops.
in THAT case... with a RWD car you have to take into consideration the power lost in the drivetrain. what about a FWD car? hardly...
a FWD car has more traction (very apptarent in snow and rain).
that is all.
Old 12-14-2005, 04:33 AM   #6
Check this out...It's a comparison between FWD/RWD
Originally Posted by Website
FWD pros:
Good traction during mild acceleration on slippery surfaces. Lighter weight helps fuel-efficiency. Interior room enhanced by lack of longitudinal driveshaft. Less expensive to manufacture.
RWD pros:
Fore-aft weight distribution more balanced. Braking performance enhanced. Tire wear more even. Cornering easier, more responsive. Lighter than AWD configuration for better acceleration and cornering performance and better fuel-efficiency. Better hard acceleration performance on good surfaces than with FWD. Better cornering ability because steering and propulsion are applied at separate axles. Greater agility because of lower resistance to changes in direction (lower moment of inertia). Longer wheelbase for smoother ride. Absence of torque steering effect common with FWD. No CV joints to replace.
That hump in RWD's is the worst thing for me, when I have to sit in the back, with one or 2 other people...can't fit my feet
Last edited by chris_knows : 12-14-2005 at 06:00 AM. Reason: Copied wrong thing :oops:
Old 12-14-2005, 05:57 AM   #7
windsonian
Dodger65's weirdo
windsonian's Avatar
he said rwd, not awd....
Old 12-14-2005, 05:58 AM   #8
Oops...just saw it ...Copied the wrong one :ohcrap, fixed now though
Old 12-14-2005, 08:20 AM   #9
FWD has more stability than a RWD in my opinion.
Old 12-14-2005, 08:54 AM   #10
aerith
@#$%ing bored out of mind
aerith's Avatar
Yeah, they do. Its just an better daily driver solution. Sure, when you take it to the extreme; it may not handle as well as RWD cars. But at the end of a 8 hour work shift and its raining, i would think the last thing you would want to worry about is fishtailing. FWD cars are just more practical if you live in a wet climate like me. I have nothing against RWD cars, it really depends on the car really.
It's the same argument about daily driving vs a sports car. With the money i spent on my car, i would've been able to afford a STi. Even though the STi outperforms it every way, its just not practical. Fuel efficency around the same if not worst (thats compared with a 3.2L V6), crappy interior, expensive insurance, and in my opinion the styling inside and out is just plain inferior. After a long day's work, you want a car that babies you, but not so sedate that you can't take it out on the weekend to have some fun. It really depends on your preference. I personally prefer luxury over pure performance, but not completely sacrificing performance either.
--2004 Acura TL Dynamic--
aerith is offline   Reply With Quote
Old 12-14-2005, 04:26 PM   #11
Performance advantage? As in 0-60, cornering, braking? None. Performance disadvantage? Until you're at the outer limits of performance? None.
Actual tuning of the chassis makes mroe differnce. A reasonably well tuned FWD car can easily perform as well as or better than a reasonably well tuned RWD car. A car like my SVT Contour had no disadvantage to a RWD car of similar size and power.
Since performance outside of ultimate racing classes and <10 second quarter miles is a wash based on layout, then the rest comes into effect. FWD gives packaging benefits in smaller cars AND luxury cars. It gives a slight advantage in inclement weather. Since most cars end up being stock (or relatively stock) street cars, the argument over FWD vs RWD tends to be mostly mental masturbation, as it's really not an important factor.
Old 12-15-2005, 06:39 AM   #12
Easier to control....but a bit hairy if a tree's fast approaching you lol
Old 12-15-2005, 07:17 AM   #13
Wally
I Know More Than You
Wally's Avatar
Less drivetrain losses.
Old 12-15-2005, 11:11 PM   #14
Halo
Originally Posted by ChrisV
. ....the argument over FWD vs RWD tends to be mostly mental masturbation, as it's really not an important factor.
lol, thats a good one
Halo is offline   Reply With Quote
Old 12-16-2005, 12:48 AM   #15
Godlaus
Godlaus's Avatar
That's the first thing that I thought of, but then I realized that a MR or RR setup would/should have the same drivetrain loss.
And ChrisV,
I disagree, perhaps you could explain why among mostly stock cars, power placement doesn't matter?
