Old 12-23-2005, 04:22 AM   #1
Anohaakten
Help with my car battery
Hey guys, I was wondering if you could tell me what to do in a situation like this. Ok, so I got subs, and my amp is 460 watts (incase you wanted to know). Anyways, I notice my battery is totally messing up. When I start my car up, the battery needle is almost all the way to the right, (a smidge past the 3/4th line). Then when my subs hit it drains some, but when I go to hit my brakes, it drains a TON and my my interior lights start to dim, and so do my headlights and my battery drains almost to 1/4th. My friend hooked it up for me and it is hooked up correctly. It is hooked up directly to the battery, I heard you can also hook it up to the fuse next to the battery? or the fuses in your car? will this help me in my situation at all? Thanks guys, I knew I could come to you
Also, I was thinking of getting an extra battery for my car, just because of this problem, I want the cheapest option, but I dont want to have problems, so I thinking of getting a Optima Red Top battery? My friend said this def. would do the trick to my situation...I was just wondering what you guys thought...? But another question is, would I run a wire from my current battery to the red top or "extra battery" to get it working? then just hook my amp up to that battery?
Thanks again guys, and sorry for such a long post
~Anohaakten
Anohaakten is offline   Reply With Quote
Old 12-23-2005, 05:50 AM   #2
I don't think setting up 2 batteries to wouldn't be what you want to do...setting them in parallel wouldn't be bad, but this is (I'm almost positive) from your alternator...
What kind of car is this, and is it automatic or standard transmissio?
Old 12-24-2005, 12:22 PM   #3
Stem
HAHA Im Stem!
ok i have some ideas here, check your alternator and battery, make sure their working together, and also its fairly common to have your lights dim when ur really subbing it, i have 1 12 and i get some dimming when i really push it. you might want to buy a capacitor, get em at walmart for about 80 bucks, they should stop the dimming. but make sure everything is hooked up right, make sure your power cable aint hitting anything else, and your ground cable could be messed up... but i cant realy think of anything of why when u hit ur breaks it messes up,
edit: go for a yellow top, and also what kind of amp and subs do you have, might help me understand the situation a bit better...
Stem is offline   Reply With Quote
Old 12-24-2005, 05:34 PM   #4
I believe that when he stops, the RPM would drop, and hence turn the alternator less, and the battery would have to provide more power to the electrical system...so I think adding a second alternator would help.
A capacitor is just for one or two songs, where there's a loud spot in the song...how would that help?
Old 12-24-2005, 05:35 PM   #5
Anohaakten
It is a 1994 Grand AM GT, Automatic, uh, I have a 460 watt amp, pushing 2 12's
Old 12-24-2005, 05:48 PM   #6
windman
add a second alternator?
lmao thats a good one
windman is offline   Reply With Quote
Old 12-24-2005, 06:01 PM   #7
What rock have you been living under for the last several years. Adding extra alternators is becoming fairly common, mostly one vehicles with substantial aftermarket ICE. I've personally done a few and my shops have done several. A few weeks ago I saw a fullsized '90ish Bronco with 14 alternators, yes fourteen. A bit of overkill, but that's how it was done.
Old 12-24-2005, 06:06 PM   #8
windman
it may very well be
but to run an amp?
and in a grand am?
where will he put it?
wouldnt a higher output amp be more realistic?
i never claimed to be the most up to date
but i think a second alt to run an amp is a bit overkill too
14 alternators what was he running?
that xmas house lights?
Old 12-24-2005, 06:28 PM   #9
Pressing the gas pedal while stopped should keep your power up...or a new (better) battery
Old 12-24-2005, 06:30 PM   #10
it may very well be
but to run an amp?
and in a grand am?
It's a stereo comp vehicle that puts out enough noise to crumble to Hoover Dam.
Old 12-24-2005, 06:50 PM   #11
I couldn't help but notice the "HAZARDOUS AREA KEEP OUT" sign
If it needs that much power, you could probably hear it at my house from Redneck Hell
Old 12-24-2005, 11:55 PM   #12
Stem
HAHA Im Stem!
capacitor would get rid of the dimming when he really hits it
Old 12-24-2005, 11:56 PM   #13
Stem
HAHA Im Stem!
yes i know that, would u mind specifying?
Old 12-25-2005, 01:38 AM   #14
When he hits it for about a second...just a spike on the power load...
Originally Posted by Dictionary.com
An electric circuit element used to store charge temporarily, consisting in general of two metallic plates separated and insulated from each other by a dielectric.
Unless there's capacitors that store power for a longer period of time...
