Old 01-11-2006, 10:41 PM   #1
jimbob88
nissan blower stays on
I have a 1994 nissan maxima. I 'am having trouble with ac blower staying on after I turn the ac off . It is a auto climate control type . When ac is on the the fan speed can not be change manually . Stays on one speed. I have to pull two fuses to turn fan off. Do I need to replace the push button control assembly? THANKS FOR ANY HELP.
jimbob88 is offline   Reply With Quote
Old 01-16-2006, 06:02 AM   #2
gawlevi
As long as the fan shuts off when turn off the key your problem should be fixed by replacing climate control head.
Check system by removing the control head and unplug harness from control head, if fan shuts off then control head is the problem- if not then you have a short in harness to fan.
gawlevi is offline   Reply With Quote
Old 02-14-2006, 10:51 PM   #3
jimbob88
Fyi. I Solved The Problem. It Was The Fan Control Amplifier. Located On The Cooling Unit Under The Dash.
