Old 01-17-2006, 01:18 AM   #1
Baowolfe
Exclamation 1995 Saturn SL1 Help
Hey everyone My name is ray and i need a hand
I Have a 1995 Saturn SL1 and for the life of me i cannot find information on where the fuel pump is and to take it to the dealer or a mechanic is well too costly any help would be great
Thank you Verry Much
Ray H.
Baowolfe is offline   Reply With Quote
Old 01-17-2006, 03:09 AM   #2
Baowolfe
If this helps at all to purchase a new fuel pump it will cost $400 Canadian im just wondering if its in the fuel tank or not the car keeps staling and sputtering on Idle i changed the plugs wires Fuel filter thermostat and Alternator all that is left is the EGR valve or the Fuel pump and i found the EGR valve but not the Fuel pump
Still lookin
Ray H.
Old 01-17-2006, 03:19 AM   #3
Baowolfe
found It
Well after much Searching i found its an In tank Fuel Pump so now the ? is Can i change it or do i have to change the whole fuel tank ??
thanx Much
ray H.
Old 01-17-2006, 07:10 AM   #4
x1/9-rally
x1/9-rally's Avatar
You'll have to drop the tank to pull the fuel pump. It should have a ring on the top of the tank that you have to turn counter clockwise, you'll have to use a flat screw driver and a hammer and tap the ring. The pump and fuel sender will come out in one piece and the fuel pump should come right off. Just be carefull when taking the fuel lines off, don't crimp them. Good luck
x1/9-rally is offline   Reply With Quote
Old 03-09-2006, 08:53 PM   #5
busrider
See my post
Sounds like you are having the same problem that I was having with my 95 Saturn SL1. In my case in turned out to be the EGR valve. Check this forum for my post to get the details.
busrider is offline   Reply With Quote
