Old 01-18-2006, 02:04 PM   #1
dudepez
RAV 4 Starting problems
I have a 1997 Toyota Rav 4, If I just turn the key the engine fires 2-3 times and then it just turns over and over. If I push the gas pedal down while turning the key it fires and starts and runs......that is until I let off the gas pedal. As soon as I do the engine just dies out.
I am assuming it is the fuel pump, but want someone to confirm this. Will the car start like this with a bad fuel pump or is there something else I should be looking at ???
dudepez is offline   Reply With Quote
Old 01-18-2006, 02:08 PM   #2
glagon1979
daddy x3
glagon1979's Avatar
is the "check engine" light on?
this forum is to dead to share a cool sig with everybody....
glagon1979 is offline   Reply With Quote
Old 01-18-2006, 02:10 PM   #3
dudepez
No Check engine light
Everytiing else is as normal when I hold the gas pedal down it runs, as soon as I take my foot off ti dies instantly
Old 01-18-2006, 02:16 PM   #4
glagon1979
daddy x3
glagon1979's Avatar
could be a number of things. from the cat. converter to fuel pump. can you hear the fuel pump turn on when you turn the key to the run position?
Old 01-18-2006, 02:20 PM   #5
Pythias
Pythias's Avatar
Check the Alternator.
"Though I drive through the valley of rice,I shall fear no turbo for torque art with me. Thy rod and piston, they comfort me."
"It is not the strong who will win, but the winner who is strong." -ROTK7
"You wrote "The World Doesn't Need A Savior" but everyday I hear people crying for one."
Pythias is offline   Reply With Quote
Old 01-18-2006, 02:22 PM   #6
dudepez
No I can not hear the fuel pump kick in when I turn the key. I had my wife go in the car and turn the key while I held my ear to the open gas cap. I heard nothing.
Old 01-18-2006, 02:24 PM   #7
dudepez
What is the ebst way to check this ?
I assume if it is bad and I have someone sit inside holding the gas down to keep it running and disconnect the battery it should die ?
But why would it start and run with the gas pedal held down and die when released if it was the alternator ?
Old 01-18-2006, 02:25 PM   #8
glagon1979
daddy x3
glagon1979's Avatar
there is your problem
whats with the " ". are you saying i dont know what i'm doing???
Old 01-18-2006, 02:27 PM   #9
glagon1979
daddy x3
glagon1979's Avatar
either take the alternator off and have it checked at a parts store, or take a volt meter and check the voltage at the battery when the car is running. it should read 14 volts or so.
Old 01-18-2006, 02:29 PM   #10
dudepez
But does that mean the fuel pump for certain ?
The last thing I want to do is sit out there and pull out the seat and play around with the fuel pump and gas in 25 degree temps if I don't have to.
I think there is a five wire plug going into the top of the access door, should more than one of them be getting power with the key turned ? of does anyone know how to jumper or ??? I can at least check to make sure powers ig going to the pump before pulling it out.
Old 01-18-2006, 02:30 PM   #11
dudepez
No that I don't know what I am doing at this time
Old 01-18-2006, 02:32 PM   #12
dudepez
Could the alternator cause it to start witht he gas pedal pressed and die when it is released ?
Old 01-18-2006, 02:32 PM   #13
glagon1979
daddy x3
glagon1979's Avatar
i wouldn't use a jumper wire around gas.
Old 01-18-2006, 02:34 PM   #14
dudepez
But I should definatly hear the pump kick in ?
Old 01-18-2006, 02:37 PM   #15
glagon1979
daddy x3
glagon1979's Avatar
yes, when you turn the key to the run position (not start) you should hear the pump "prime" itself.
