Old 02-10-2006, 06:18 AM   #1
Bugatti Veyron, Got this in an email
Bit of a read but worth it
When you push a car past 180mph, the world starts to get awfully fizzy and a little bit frightening. When you go past 200mph it actually becomes blurred. Almost like you're trapped in an early Queen pop video. At this sort of speed the tyres and the suspension are reacting to events that happened some time ago, and they have not finished reacting before they're being asked to do something else. The result is a terrifying vibration that rattles your optical nerves, causing double
vision. This is not good when you're covering 300ft a second. Happily, stopping distances become irrelevant because you won't see the obstacle in the first place. By the time you know it was there, you'll have gone through the windscreen, through the Pearly Gates and be half way across God's breakfast table.
It has always been thus. When Louis Rigolly broke the 100mph barrier in his Gobron in 1904, the vibration would have been terrifying. And I dare say that driving an E-type at 150mph in 1966 must have been a bit sporty as well.
But once you go past 200mph it isn't just the suspension and the tyres you have to worry about. The biggest problem is the air. At 100mph it's relaxed. At 150mph it's a breeze. But at 200mph it has sufficient power to lift an 800,000lb jumbo
jet off the ground. A 200mph gust of wind is strong enough to knock down an entire city. So getting a car to behave itself in
conditions like these is tough.
At 200mph you can feel the front of the car getting light as it starts to lift. As a result you start to lose your steering, so you aren't even able to steer round whatever it is youcan't see because of the vibrations. Make no mistake, 200mph is at the limit of what man can do right now. Which is why the new Bugatti Veyron is worthy of some industrial strength genuflection. Because it can do 252mph. And that's just mad - 252mph means that in straight and level flight this car is
as near as makes no difference as fast as a Hawker Hurricane.
You might point out at this juncture that the McLaren F1 could top 240mph, but at that speed it was pretty much out of control. And anyway it really isn't in the same league asthe Bugatti. In a drag race you could let the McLaren get to 120mph before setting off in the Veyron. And you'd still get to 200mph first. The Bugatti is way, way faster than anything else the roads have seen.
Of course, at 810,000, it is also jolly expensive, but when you look at the history of its development you'll discover it's rather more than just a car . . .
It all started when Ferdinand Pich, the swivel-eyed former boss of Volkswagen, bought Bugatti and had someone design
a concept car. "This," he said, "is what the next Bugatti will look like." And then, without consulting anyone, he went on.
"And it will have an engine that develops 1000 horsepower and it vill be capable of 400kph."
His engineers were horrified. But they set to work anyway, mating two Audi V8s to create an 8 litre W16. Which was then garnished with four turbochargers. Needless to say, the end result produced about as much power as the earth's core,
which is fine. But somehow the giant had to be cooled, which is why the Veyron has no engine cover and why it has 10 count them - 10 radiators. Then things got tricky because the power hadto be harnessed.
For this, VW went to Ricardo, a British company that makes gearboxes for various Formula One teams. God, it was hard," said one of the engineers I know vaguely. "The gearbox in an F1 car only has to last a few hours.Volkswagen wanted the Veyron's to last 10 or 20 years. And remember, the Bugatti is a damn sight more powerful than any F1 car." The result, a seven-speed double-clutch flappy paddle affair, took a team of 50 engineers five years to perfect.
With this done, the Veyron was shipped to Sauber's F1 wind tunnel where it quickly became apparent that while the magic 1000bhp figure had been achieved, they were miles off the target top speed of 400kph (248mph). The body of the car
just wasn't aerodynamic enough, and Volkswagen wouldn't let them change the basic shape to get round the problem.
The bods at Sauber threw up their hands, saying they only had experience of aerodynamics up to maybe 360kph, which is the effective top speed in Formula One. Beyond this point Bugatti was on its own. Somehow they had to find an extra 30kph, and there was no point in looking to the engine for answers because each extra 1kph increase in speed requires an extra 8bhp from the power plant. An extra 30kph then would need an extra 240bhp. That was not possible. The extra speed had to come from changing small things on the body. They started by fitting smaller door mirrors, which upped the top speed a bit but at too high a price. It turned out that the bigger ones had been keeping the nose of the car on the ground. Without them the stability was gone. In other words, the door mirrors were generating downforce. That gives you an idea of how much of a bastard the air can be at this speed.
After some public failures, fires and accidents, and one chief being fired, they hit on the idea of a car that automatically changes shape depending on what speed you're going. At 137mph, the nose of the car is lowered by 2in and the big rear spoiler slides into the slipstream. The effect is profound. You can feel the back of the car being pressed into the road. However, with the spoiler in place the drag is so great you're limited to just 231mph. To go faster than that you have
to stop and insert your ignition key in a slot on the floor. This lowers the whole car still further and locks the big back wing down. Now you have reduced downforce, which means you won't be going round any corners, but you have a clean shape. And that means you can top 400kph.
That's 370ft a second. You might want to ponder that for a moment. Covering the length of a football pitch, in a second, in a car. And then you might want to think about the braking system. A VW Polo will generate 0.6g if you stamp on the middle pedal hard. You get that from the air brake alone on a Veyron. Factor in the carbon ceramic discs and you will pull up from 250mph in just 10sec. Sounds good, but in those 10sec you'll have covered a third of a mile.
That's five football pitches to stop. I didn't care. On a recent drive across Europe I desperately wanted to reach the top speed but I ran out of road when the needle hit 240mph. Where, astonishingly, it felt planted. Totally and utterly rock steady. It felt sublime. Not quiet, though. The engine sounds like Victorian plumbing - it looks like Victorian plumbing as well, to be honest - and the roar from the tyres was biblical. But it still felt brilliant. Utterly, stunningly, mind blowingly, jaw droppingly brilliant.
And then I reached the Alps where, unbelievably, it got better.I expected this road rocket to be absolutely useless in the bends but it felt like a big Lotus Elise.
Occasionally, if I accelerated hard in a tight corner, it behaved strangely as the four-wheel-drive system decidedwhich axle would be best equipped to deal with the wave of power. I won't say it's a nasty feel or dangerous. Just weird, in
the same way that the duck-billed platypus is weird.
View a photo gallery of the Bugatti Veyron
You learn to raise an eyebrow at what's only a foible, and then, as the road straightens out, steady yourself for Prince Albert's boiler to gird its loins and play havoc with the space-time continuum. No, really, you come round a bend, see what appears to be miles and miles of dead straight road, bury your foot in the carpet and with a big asthmatic wheeze, bang, you're instantly at the next bend, with your eyebrow raised again.
From behind the wheel of a Veyron, France is the size of a small coconut. I cannot tell you how fast I crossed it the other day. Because you simply wouldn't believe me. I also cannot tell you how good this car is. I just don't have the vocabulary. I just end up stammering and dribbling and talking wide-eyed nonsense. And everyone thinks I'm on drugs. This car cannot be judged in the same way that we judge other cars. It meets drive-by noise and emission regulations and it can be driven by someone whose only qualification is an ability to reverse round corners and do an emergency stop. So technically it is a car. And yet it just isn't.
Other cars are small guesthouses on the front at Brighton and the Bugatti is the Burj Al Arab. It makes even the Enzo and the Porsche Carrera GT feel slow and pointless. It is a triumph for lunacy over common sense, a triumph for man over nature and a triumph for Volkswagen over absolutely every other car maker in the world.
VITAL STATISTICS
Model Bugatti Veyron 16.4
Engine 7993cc, 16 cylinders in a W
Power 1001bhp @ 6000rpm
Torque 922 lb ft @ 2200rpm
Transmission 7-speed DSG, manual and auto
Fuel 11.7mpg (combined)
CO2 574g/km
Acceleration 0-62mph: 2.5sec
Top speed 253mph
Price 810,345
Rating Five stars
Verdict Deserves 12 stars. Simply as good - and as fast - as it gets
Old 02-10-2006, 06:22 AM   #2
that was definetely an intersting read cool
Old 02-10-2006, 06:25 AM   #3
bebopin64
that car amazes me
bebopin64 is offline   Reply With Quote
Old 02-10-2006, 06:31 AM   #4
as this is a very amazing machine no doubt, I think its turning into starbucks and being overdone because it seems to be comming up everywhere!
Old 02-10-2006, 06:32 AM   #5
Good read...
You have to put the key into a special slot to reach the top speed?
Also, I'm surprised with the 11.7mpg...I've seen Mustangs get worse than that...
Old 02-10-2006, 06:42 AM   #6
Great read!!!
Old 02-10-2006, 06:52 AM   #7
Good read...
at top speed doesn't it get like 1 mile a gallon or something close to that? I remember reading it somehwere
Old 02-10-2006, 06:59 AM   #8
On an episode of Top Gear Jeremy was driving a McLaren SLR and said that at top speed (+200mph) the SLR would eat through a full gas tank in under 20 minutes. Try doing the math on that.
Old 02-10-2006, 07:02 AM   #9
Yeah in C/D I've seen that but I can't remember what it was...
Checked the magazine (November 2005 if anyone cares lol) and it's 3mpg at a steady 254 mph
Also, 7mpg/city
and 10 highway...
It also says that there's flaps in the front to relieve air pressure that builds up ahead of the tires...pretty crazy
Old 02-10-2006, 07:09 AM   #10
I believe the top speed is exactly 200mph, so with the fuel tanks totalling ~26 gallons...2.564mpg is what I got...
That's pretty terrible...unless my math is off, but from 600 horsepower, it could do a bit better than that, but at lower speeds I've heard it does pretty good...
Old 02-10-2006, 07:13 AM   #11
shadowedII
shadowedII's Avatar
you'd probably need a new insurance company to insure that beast. in the top gear episode where jeremy races a veyron against the other guys who are in a cesna (south of france to london, i believe), he calls his insurance company and the guy doesn't even know what a bugatti is... and they dont insure it, obviously.
it would suck to be the sorry guy to crash into one...
shadowedII is offline   Reply With Quote
Old 02-10-2006, 07:29 AM   #12
If you had the money to buy one and run it why would you bother about insurance?
Old 02-10-2006, 07:39 AM   #13
Ecxellent, read, I never really thought of it that way, but the author writes very convincingly. Up untill now I just thought of is as....faster.
Old 02-10-2006, 07:42 AM   #14
shadowedII
shadowedII's Avatar
no... but i just might have the tendancy to speed... and the fuzz just might have the tendancy to get a little annoyed if i was tripling the speed limit and was un-insured.
then again, i'm pretty sure that no crown victoria could keep up with a veyron either...
hmmm, i seem to find myself at an imaginary crossroad!
Old 02-10-2006, 08:08 AM   #15
I'd definatelly get some lol......not sure I'd wanna be an insurance company who has to pay our for a written off one though lol.
Great read btw.....that's the most copy/pasting you've ever done isn't it? jk
