Old 02-24-2006, 06:40 PM   #61
thunderbird1100
CF dB-o-holic
Some are only plastic.....alot of them are copper though I believe
I've only seen rubber thats why i said i think they only are rubber. But plastic and copper ones? Has a better chance of leaking no?
1990 Honda Accord LX Sedan
Mileage Ticker: 232,400 Miles
Stereo Mods: Coming soon...
~Blow your mind~
Old 02-24-2006, 06:41 PM   #62
thunderbird1100
CF dB-o-holic
Huh?
= Retarded
= Just plain stupid and ignorant and wont change mind
= me ROFL
~Blow your mind~
Old 02-24-2006, 06:42 PM   #63
Not really as both are fairly soft and will be squeazed nicely between the sump plug and the sump itself
Old 02-24-2006, 08:20 PM   #64
= Retarded
= me ROFL
Yea....because me saying that my car on synthetic runs smoother, gets better mpg, and keeps at a lower rpm (due to changing from 10W-40 to 5W-30) is completely rediculous right? I call to you pal.
Old 02-24-2006, 08:26 PM   #65
thunderbird1100
CF dB-o-holic
runs smoother
Probably does.
gets better mpg
Mine does as well.
Completely rediculous, absolutely inane, dumb, retarded, ignorant...I could think of more words, but you get the idea.
It's not all completely rediculous, just the last statement. Kind of funny calling me a tard when no one is siding with your statement or is going to.
End.
~Blow your mind~
Old 02-24-2006, 08:34 PM   #66
Probably does.
Mine does as well.
End.
Dont care who is siding with me. I said the rpm dropped because I went from thicker 10W-40 to 5W-30.
EDIT> Cars on synthetic get better MPG. Arent you curious as to how its possible?
Old 02-24-2006, 08:38 PM   #67
Yes, and you were also told that the oil wont affect that, right?
Old 02-24-2006, 08:48 PM   #68
OK Cliff and others. How does Synthetic 5W-30 vs. Conventional 10W-40 save gas? You say the RPM doenst drop. I didnt get magical stickers or oil filter for my car. Just a simple oil change. If you dont accept my theory, then how does synthetic save gas.
Old 02-24-2006, 08:49 PM   #69
synthetic oil makes it so that it causes less friction than conventional oil does and so less friction means less heat and less heat means less fuel consumption. correct me if im wrong
Old 02-24-2006, 08:52 PM   #70
And less friction means less work for the engine....hence lower consumption. At a guess
Old 02-24-2006, 08:55 PM   #71
I'm going to take hobos advise and put in a simple question directed towards him so....
HOBO, how does synthetic oil save gas? (I also believe that by putting in synthetic oil doesn't neccessarily mean that you will save gas, but there is a higher chance that you will)
Old 02-24-2006, 09:15 PM   #72
And less friction means the cylinders flow more freely, and keep at a lower rpm, where there is more friction and they are higher?
Old 02-24-2006, 09:20 PM   #73
I would say they move more efficently not freely because they are still moving at the same rate they are just causing more power. Wouldn't it be like a spinning a wheel at the same rate. You have to put more effort into spinning the wheel if it is spinning on a dirty joint. Now clean that joint up and it will still spin at the same rate, but with less effort making it more efficient.
Old 02-24-2006, 09:50 PM   #74
So thats why my RPM dropped. At 60, they dont have to work as hard to produce and keep the speed, so they can work at a lower RPM and give the same power they would with conventional at a higher RPM. Make sense?
Old 02-24-2006, 09:52 PM   #75
Erdrickk
Hate to break it to you Newyorker but Synthetic oil in no way reduces your RPM's It reduces Friction, which allows the engine to move the pistons with less effort = less heat which can improve gas mileage. With regular oil the pistons are still being moved at the same pace, but it takes more work for the engine to do it......but its always the same rpm's no matter what the hell you put in to it.
Erdrickk is offline   Reply With Quote
