Old 02-23-2006, 09:39 PM   #1
GonnaDie4TheGov
CF's Only Jersey Boy
GonnaDie4TheGov's Avatar
Max Power
Whats the max wattage you could/should pull with a 4 gauge wire? I should know this but i don't...i jsut know it starts at like 800 watts so im assuming that its max is around 2000.
2001 Honda K-1 Accord Attack
GonnaDie4TheGov is offline   Reply With Quote
Old 02-23-2006, 11:32 PM   #2
windsonian
Dodger65's weirdo
windsonian's Avatar
http://www.powerstream.com/Wire_Size.htm
Old 02-24-2006, 06:59 PM   #3
thunderbird1100
CF dB-o-holic
Whatever the biggest power/ground wire gauge the amp accepts, use that, you cant mess it up. Dont try and use 4 gauge wire to an amp that accepts 0ga power/ground wire. Worst that would happen is (if you used an inline fuse) the fuse will blow, but still you wasted your money on buying a 4ga amp kit.
As a rule of thumb I'd use either 12ga or 14ga speaker wire to my subs and either 14ga/16ga (Sometimes can get by with 18ga to aftermarket speakers) to components/coax.
1990 Honda Accord LX Sedan
Mileage Ticker: 232,400 Miles
Stereo Mods: Coming soon...
~Blow your mind~
