Old 02-28-2006, 01:59 AM   #1
Jim Hatton
Talking 95 Chev Van G20 Poor pickup
My 95 chev G20 van, has poor pickup. The trans was rebuilt and now shifts in all gears. If I start out slow it will gradually get up to speed. If I put it to the floor I get what I call a flat spot ( nothin) let off a little some power comes back. Up grade I have to pepper it alot. Midas said the converter was good. I have replaced the air filter, plugs and a throttle sensor. Any help would be greatly appreciate.
Thanks
Jim
Jim Hatton is offline   Reply With Quote
Old 02-28-2006, 02:49 PM   #2
glagon1979
daddy x3
glagon1979's Avatar
your catylitic(sp?) converter could be plugged
this forum is to dead to share a cool sig with everybody....
glagon1979 is offline   Reply With Quote
Old 03-01-2006, 01:49 AM   #3
Jim Hatton
Talking
Midas Muffer checked and said the converter was ok.
Old 03-02-2006, 06:32 AM   #4
Golddragoner
Is it a carb or fuel injection? with a carb, you could possibly get the throttle body spacer which would increase the performance and most likely get rid of that flat spot. With Fuel Injection, it could be that one of the injectors is plugged up a little causing it to not allow enough fuel to get through for the amount of air, thereby causing you to run really lean. Or of course your fuel pump sucks
Old 03-02-2006, 01:13 PM   #5
glagon1979
daddy x3
glagon1979's Avatar
in 1995 chevy had pretty much done away with carburators.
Old 03-03-2006, 06:17 PM   #6
carls47807
CF Freak
could be your detent cable or something, is it downshifting?
