Old 03-09-2006, 04:38 AM   #61
illusion34
ya.. what about my monte carlo question tho?
illusion34 is offline   Reply With Quote
Old 03-09-2006, 04:41 AM   #62
PontiacFan27
PontiacFan27's Avatar
Originally Posted by illusion34
but does displacement play a huge role? would that mean a 6.6 litre 403 (t/a) would piss all over the 5 litre 302(stang)?
Displacement is only important if you think about it this way. In ideal conditions, where flow, coolant flow, spark, valvetrain durability, octane and all other factors were perfect, the higher displacement will be better. But this isnt a perfect world. There are bad head designs, low compression (stupid EPA shit!), valve float, cooling issues, etc. that can make a smaller engine produce more power because the bigger engine had flaws.
PontiacFan27 is offline   Reply With Quote
Old 03-09-2006, 04:45 AM   #63
illusion34
ok.. but the monte carlo wuestion.. i like fell in love with that car now! its kinda like a sleeper.. perfect for burning those civics and ppl around
Old 03-09-2006, 05:35 AM   #64
Yes, the 83'-88' Monte Carlos were carb.
Old 03-09-2006, 05:42 AM   #65
illusion34
nice.. now is it easy to find 86 monte carlo ss's around for under 8000$ do they have 5.0's?
Old 03-09-2006, 05:49 AM   #66
I'm not sure about prices (I'll try and take a quick look), and yes, the SS had a 305 H.O in them.
Check out this site if wanted: http://www.montecarloss.com/
Old 03-09-2006, 05:57 AM   #67
Pythias
Pythias's Avatar
Originally Posted by PontiacFan27
I've seen them for as low as 3500 around here, and thats in good condition.
Yes and there are clean foxes around here for 1,000$ Galore.
"Though I drive through the valley of rice,I shall fear no turbo for torque art with me. Thy rod and piston, they comfort me."
"It is not the strong who will win, but the winner who is strong." -ROTK7
"You wrote "The World Doesn't Need A Savior" but everyday I hear people crying for one."
Pythias is offline   Reply With Quote
Old 03-09-2006, 06:00 AM   #68
illusion34
around where
the reason i like the carlos is cause there sleepers
and the irocs casue u almos tnever see em round hear...
but for 1g..
Old 03-09-2006, 06:01 AM   #69
Okay, quick look on value guides says that an 86' Monte SS is worth less then $8000.. that's not saying they will all sell for that, but you should be able to find them reasonably priced.
There's a regular Monte listed on here for $5400 (I think it was), just scroll to the bottom(ish): http://carsforsale.classifieds1000.c...et/Monte_Carlo
(Plus it's relatively close to you... Ontario).
Old 03-09-2006, 06:05 AM   #70
illusion34
nice..
does anyone know why people say the tuned port iroc-z was a special car in the 80's.. by special i mean a street prowler
Old 03-09-2006, 06:12 AM   #71
nice..
TUNED PORT INJECTION (TPI) is multiport fuel injection system where the runners have been specifically "tuned" to perform optimally at a given RPM range. (TPI) appeared on General Motors vehicles in 1985 (Corvette, Camaro, Pontiac Firebird & Trans AM). Labratories conducted numerous test on the TPI systems indicated that increases of up to 35% in Horsepower, torque and economy over carbureted systems. Since 1983 GM had Borg-Warner T5 five-speed transmission for Camaro, which was never designed for high-performance use and was only rated for up to 300 pounds per foot of torgue (T5s, used 1983-1987 weren´t even designed to handle that much). So torque of the 350 cid TPI was brutal enough to destroy this unit (torque > 300 ft/lbs). So option was limited to the four-speed automatic TH700R4 trans
That should help explain it alittle better, just quickly read that.
Old 03-09-2006, 06:16 AM   #72
illusion34
thanks.. my problem is.. i want the car out of those that is really like a classic.. not one of those cars that was all advertising and had no go.. i like the monte because its a sleeper... the camaro looks nice but would it be able to hold its own against a monte?
Old 03-09-2006, 06:37 AM   #73
Stock:
85'-86' Iroc Camaro (TPI): 190HP 285TQ
87' Iroc Camaro (TPI): 190HP 295TQ
88' Iroc Camaro (TPI): 195HP 295TQ
Stock:
83' Monte Carlo SS: 175HP 230TQ
84' Monte Carlo SS: 180HP 225TQ
The Camaro link: http://www.geocities.com/MotorCity/G...motorspec.html
That's the best I can get... it's harder to find the HP ratings on the Monte Carlo so I may be alittle off there. Weight of each car would also kind of play a factor, like if the Camaro weighs a lot more then the Monte, then that could set of the Power to Weight ratio. Personally I'd go with whatever one you like the looks of more, they both seem kind of even in the power (not sure of weight) so it's not a whole lot of difference.
Old 03-09-2006, 06:49 AM   #74
illusion34
wow thanks for all the info man. well.. another deciding factor.. the monte would have more space for a sick sound system wouldnt it..
Old 03-09-2006, 06:54 AM   #75
It's no problem. I think the Monte would have more space for stuff like that with the bigger trunk then a Camaro would with a small(er) space in/under the hatch... plus people can see what you have in the Camaro through the hatch window (example: your system and other valueables that may look tempting to steal).
