Old 03-06-2006, 10:16 PM   #1
MetalManiac
MetalManiac's Avatar
Question 14" to 17" wheels
What would I have to do to my car if I wanted to change my car's wheels
from 14" wheels to 17" wheels?
Buying tires is obvious, but what about suspension,body work or anything else?
Approx how much would it cost?
MetalManiac is offline   Reply With Quote
Old 03-06-2006, 10:19 PM   #2
completly depends on your vehicle,
if your talking about the jeep, then it shouldnt be a problem i dont think
unless you have really tall tires
Old 03-06-2006, 10:23 PM   #3
Yeah, depends on what car...they might cause some problems, but it depends on the profile of the tires...and almost definitely the speedometer will need to be retuned...
Old 03-06-2006, 10:53 PM   #4
MetalManiac
Its a 1994 honda accord (my first car)
Speedometer retuned?
Old 03-06-2006, 10:56 PM   #5
we thought u meant the jeep lol,
17's still shouldnt be a problem,
and the speedometer would need to be retuned just so its still accurate
comes from the factory tuned for 14 inch wheels I would assume
Old 03-06-2006, 11:11 PM   #6
Not sure if they would fit, but I'm sure some other members would...But what I meant by speedometer retuned is that since the wheels will be a different size, the speedometer will be reading the wrong speed...usually by like 5 miles or so, but it's a good idea to retune it...
Old 03-07-2006, 12:03 AM   #7
GonnaDie4TheGov
CF's Only Jersey Boy
GonnaDie4TheGov's Avatar
Your 94 accord has 14" wheels? Mine are stock size and are 15's. And mines a 96...basically the same model
2001 Honda K-1 Accord Attack
GonnaDie4TheGov is offline   Reply With Quote
Old 03-07-2006, 12:10 AM   #8
They really are 14" wheels, at least according to the Haynes Data Book lol...
Old 03-07-2006, 02:01 AM   #9
Keep the overall size of the wheel the same and youl be fine. I know that my wheel is 23.5 inches diameter with tires, 14in rim and 65 profile tire. I know if I want 17s I need 40 or 45 profile tires to not recalibrate the speedo (simply because 50 wont fit in the wheelwell).
Old 03-07-2006, 02:22 AM   #10
MetalManiac
Oh cool now I know
Old 03-10-2006, 04:39 PM   #11
Golddragoner
Its usually best to go down 10 in profile for every rim size you upgrade. That way, the tire is APPROXIMATLY the same size and won't screw the ABS or speedo up too much. So going from 14" to 17" You would need to go down 30 in profile. so if your tires are 195/70/R14 then you need 195/40/R17
Old 03-12-2006, 01:05 AM   #12
MetalManiac
My tires are 185/70/R14. Rims I want to get are 17x7.
I went into a tire web site and recommended I used 205/45/R17(Wider tires) better look than stock tires width size(185), well at least for me. I guess that means more problems with my speedo tho'. Oh and by the way do any of you know how to retune the Speedometer?
Old 03-12-2006, 01:18 AM   #13
A local mechanic might, same with a speeshop...It might not need retuning if you change the profile, and I don't think width affects it...
Old 03-12-2006, 03:47 PM   #14
I've never known anybody to actually do this after fitting new wheels....maybe it's because the implication's so minor?
Old 03-12-2006, 05:09 PM   #15
It would probably depend on the size change, and if he's changing them like that, then his sidewall would be 1.5" smaller, so the new tires would be just 1.5" bigger...so he probably won't need it anyhow.
