Old 03-06-2006, 10:44 PM   #1
dan401964
98 jeep cherokee 4.0l
I replaced the thermostat and lower radiator hose but it is now leaking from behind the lower hose and is overheating and I have no heat any suggestions?
Also when i first start it and I drive it it will die and I have to wait a couple of minutes before it turns over and then I have to put foot to the floor to get it to start!
Thank You
Dan
dan401964 is offline   Reply With Quote
Old 03-07-2006, 01:58 AM   #2
97Talonchik
discombobulated
97Talonchik's Avatar
Did you close the drain cock? Did you put the hose clamps back on? Did you use a new gasket? Did you remove the old gasket? Did you use a sealant on the gasket? Did you accidentally disconnect a vaccum hose?
Old 03-08-2006, 04:47 PM   #3
carls47807
CF Freak
sounds like it is flooding out. make sure thermos is in right as baxler said and make sure your coolant temp sensor connector is on well. any codes?
