Old 03-08-2006, 07:31 PM   #1
caking74
95 Honda Accord EX sunroof leak
I reside in the Pacific NW and have a 95 Honda Accord EX that I believe has a moonroof/sunroof leak. During the recents down pours the back seat bottom and the drivers front and back floor were soaked. I would like to know if anyone has had a similiar problem. Thanks
caking74 is offline   Reply With Quote
Old 03-08-2006, 10:36 PM   #2
Maybe its coming through the floor?
Old 03-09-2006, 12:38 AM   #3
97Talonchik
discombobulated
97Talonchik's Avatar
The floor??
Caking, check your sunroof/moonroof's weatherproofing (the black rubber around it). See if there are any holes or tears in it that you can see. This can cause a leak. I've had this happen on my hatchback.
Old 03-09-2006, 12:43 AM   #4
Originally Posted by 97Talonchik
The floor??
My aunt had a 94 EX and she had the same problem, I checked out the seals and they were dry rotting (because of the Florida climate) and I replaced her seals and it stopped it right then
Old 03-09-2006, 01:51 AM   #5
I said the floor because he siad its on the floor...I know for a fact that when it rains, I get water or moisture for that matter into my spare tire compartment and under the back seat...why...because the seals or some shit are worn it doenst bother me because it doenst rain all that much around here
Old 03-09-2006, 01:57 AM   #6
Umm, seals around where the spare tire is located??? Bro that shits welded
Old 03-09-2006, 01:59 AM   #7
My back seat is held in by locks, and the rubber gaskets for them are basically going thru the car so they might be worn...as far as the spare thing goes i duno
Old 03-09-2006, 02:27 AM   #8
Godlaus
UnFedFat in Disguise
Godlaus's Avatar
i duno
I think this sums up your usefulness on CF.
I am everything you want to be
Old 03-09-2006, 02:39 AM   #9
I love how you just quote a small phrase in my whole response. BTW hows that fanclub going I see members are thriving
Old 03-09-2006, 03:16 AM   #10
97Talonchik
discombobulated
Your weatherproofing on your trunk is probably shot. You might want to check it for tears, etc.
Old 03-09-2006, 03:52 AM   #11
I was washing my car today and was scared id get wated in there on the SUB and AMP but it was OK. Thanks for the tip doll.il look into it right after i get my rims friday
Old 03-09-2006, 07:03 AM   #12
Godlaus, I suggest you remove that fan club invitation from your sig, as it doesn't do CF any favours and certainly doesn't do your reputation much good! As much as newyorker annoys us some times, lets not start hatred through sigs please! If you fail to remove it, I will
As for the question in hand. It's quite possible the water got in through the floor, depending on it's condition obviously. and spare tyre compartments usually have a rubber plug in them to drain any wter that gets in....if that's relevent lol
