Old 03-15-2006, 11:53 PM   #1
transmission shifting problem
say i have a 94 intrepid with a particular shifting problem? when i start out in the morning and after work the car goes into drive just dandy then after i drive about 1/8th mile to the stops going home or to work the trans seems to go into neutral and after i stop completely it will go back into drive and then at the next stop about 1/16th mile future down the road either way it will do this again and then it is done and shifts just dandy once again. does anyone happen to have a possible cure for this problem? or maybe have the problem and had it checked out and told not to worry??? thanks bob.
corvairbob is offline   Reply With Quote
Old 03-16-2006, 06:14 PM   #2
Have you checked your tranny fluid recently? If it's low the tranny will tend to slip a little. Either that or else the tranny just simply needs to be replaced. Chrysler trannys aren't great.
Old 03-20-2006, 04:06 AM   #3
I have the same problem on my 91 sundance, does anyone know if its maybe the torque converter or timing belt?
madlf is offline   Reply With Quote
Old 03-20-2006, 04:34 AM   #4
Had this happen on my 1990 Pontiac 6000LE...turns out there was NO tranny fluid...added it, and everytihng was OK
