Old 03-19-2006, 07:46 PM   #1
dmunson_us
Gas Overload
I have a SBC 350 with a 750 edelbrock and it seems to over load the spark plugs and cause it to mis - can I use a different plug with a higher spark or?
dmunson_us is offline   Reply With Quote
Old 03-19-2006, 08:32 PM   #2
Huh? Do you have any clue what it is you're talking about or what you're asking? A plug with a higher spark? WTF???
Old 03-19-2006, 08:53 PM   #3
I think he means a spark plug with a higher intensity spark.....you can try Bosch Platinum +4
Old 03-19-2006, 10:23 PM   #4
Wally
I Know More Than You
Wally's Avatar
If something is snuffing the flame, you should really address the cause. If you are overfueling and like it that way then you need to consider the heat range of the plug. Of course bore wash, etc are just side issues.
Old 03-19-2006, 11:53 PM   #5
Newsflash Twinkie. A Bosch Platinum +4 plug DOES NOT have a higher intensity spark that a normal sparkplug.
Old 03-20-2006, 05:59 AM   #6
Golddragoner
umm really you can't get a 'higher intensity" spark plug. Even if you get a very high powered coil, it only uses what it needs for the spark to get across the gap. So whether the coil is way overrated or just right it gives the exact same spark.
Old 03-20-2006, 06:34 AM   #7
Wally
Wally's Avatar
Is that right? So if I have a potential of 40kV between two electrodes and another with 20kV the arc will not be any different?
Old 03-20-2006, 07:44 PM   #8
Sick88Tbird
Master of the Fox-chassis
Sick88Tbird's Avatar
I would recommend trying to adjust your floats, but I'm sure you have no clue what that is. You can also try using a set of plugs with a higher heat range...but that is more or less a band-aid for poor carb sizing/tuning.
New Toy- Stone stock '88 T-bird Sport in need of some TLC
1988 Cougar XR-7- HO/T-5 conversion, cracked block prevented from reaching full potential.
RIP '88 T-Bird....14.1@98.7mph...best sleeper in So. Jersey, now it's taking a permanent dirt nap.
Sick88Tbird is offline   Reply With Quote
Old 03-20-2006, 08:13 PM   #9
glagon1979
daddy x3
glagon1979's Avatar
is the engine stock? I run r45ts (ac delco) in my 350 but its not stock. we need a little more info in order to help out, that is if you know what you are talking about
this forum is to dead to share a cool sig with everybody....
glagon1979 is offline   Reply With Quote
Old 03-20-2006, 10:22 PM   #10
So the box says "delivering the most powerful spark" for no reason at all?
Old 03-20-2006, 10:24 PM   #11
The containers of most fuel addatives usually say something like "guarenteed hp increase"....and most of the time it's BS. Yes the spark plugs have hotter/cooler intensities....but not too sure about "the most powerfull spark"...
Old 03-20-2006, 10:27 PM   #12
No, there IS a reason. It's called advertising. It's called convincing know nothings that they actually know something. New, improved, better than before. Ever heard those phrases? If you want to argue the point, explain to us why and/or how they "deliver the most powerful spark". Remember, science not slogans.
Old 03-21-2006, 07:07 AM   #13
Sick88Tbird
The thinking behind the Bosch-2 and +4 spark plugs is that moving the ground electrodes out will unshroud the spark...racers have been indexing plugs for years to try and gain that extra few hp by unshrouding the spark...but on a typical street/strip application it would most likely be worth nothing.
Old 03-21-2006, 07:21 AM   #14
Don't flame for asking a stupid question, but wouldn't that mean that since the higher intensity spark plugs make a bigger/stronger spark, they'd need more electricity, which would lower horsepower?
Old 03-21-2006, 08:07 AM   #15
Wally
Wally's Avatar
I thought the four prongs just means there are four alternative paths to ionise the air and jump a spark.
