Old 03-23-2006, 05:57 PM   #1
Trapstar420
help
man i am jus wondering will
•2 x 1000 RMS at 4 OHMS
•2 x 2000W MAX at 4 OHMS
•1 x 4000W MAX at 4O HMS Bridged
Product Description:
Lanzar Car Audio "Viberant" 2-Channel Audio Amplifier 4000 Watts Max
Details:
·2 x 1000 RMS at 4 OHMS ·2 x 2000W MAX at 4 OHMS ·1 x 4000W MAX at 4O HMS Bridged ·2 x 1650W at 2 OHMS ·Electronic Crossover Network ·Bass Boost Circuit ·2 Ohms Stereo Stable ·Anti-Thump Turn-On ·Illuminated Top Panel ·Soft Turn ON/ Off ·High & Low Level Inputs ·Power & Protection LED Indicators ·Advanced Protectin Circuitry ·Remote Control Bass Booster ·Dimensions: 11.06''W x 2.24''H x 21''L ·T.H.D: < 0.04% ·S/N Ratio: > 90dB ·Channel Separation: >65dB ·F·req. Response: 15 Hz - 35KHz
will that go well with 2 adeobahn 15 1100 watts a peice
if i run say only haf the amps power
Trapstar420 is offline   Reply With Quote
Old 03-23-2006, 06:01 PM   #2
Details:
Hi, my name is XXXX. I just found this forum and it seems really decent. I'm working on a stereo system for my car and was wondering if someone with more experience would be willing to lend a hand. Thanks in advance for your time and help, if you need any more info to clarify what I'm doing just let me know.
Self-centered jerkoff.
Old 03-23-2006, 06:52 PM   #3
thunderbird1100
CF dB-o-holic
Details:
Any amp in the Lanzar line besides the OPTI versions are VERY overrated (Even some OPTI version are pretty overrated). No way does that amp put out 2x1000rms @ 4ohm...NO WAY. Not NEARLY big enough...Plus, it doesnt even put out clean power. Buy a good amp, not a cheap overrated amp. When a friend and myself benched a Lanzar Vibe 258 (rated at 2x400rms @ 4ohm) it did a whooping 122 watts per channel @ 4ohm at an INCREDIBLY high distortion of 12%. Most good 2-channel amps can accomplish their RATED power with a 1% distortion. Not to mention the SQ qith the Vibe line is horrendous (90db S/N).
1990 Honda Accord LX Sedan
Mileage Ticker: 232,400 Miles
Stereo Mods: Coming soon...
~Blow your mind~
Old 03-23-2006, 11:46 PM   #4
davsmitty
davsmitty's Avatar
have yall seen the Soundsteam XXX sub amp? DAMN thats big!
davsmitty is offline   Reply With Quote
Old 03-27-2006, 06:55 AM   #5
doctor
wow nice amp there .. how much it all cost you ?
No advertising!
Signature removed
You may remove this message once read!
doctor is offline   Reply With Quote
