Old 04-01-2006, 11:31 PM   #16
Bubba
null
Is it good now?
Also I guess this kinda falls in here, how can I increase my resolution without having to scroll around the screen?/Is it possible? lol
Not quite sure if i understand, increasing resolution puts more stuff on the screen so you wouldn't have to scroll as often.
Bubba is offline   Reply With Quote
Old 04-01-2006, 11:32 PM   #17
Is it good now?
You could always press F11 on your keyboard.......and yours looks better now!
Old 04-01-2006, 11:38 PM   #18
what does F11 do I hit it, but it didn't work. Maybe you can try alt+F4
Old 04-01-2006, 11:42 PM   #19
Bubba
null
F11 makes your browser go into full screen mode, at least for firefox and Explorer
Old 04-01-2006, 11:45 PM   #20
oh, thats how I usually view the screen anyways. This is off topic, but do you know what the refresh rate does and should I increase it?
Old 04-01-2006, 11:48 PM   #21
Alt+F4? I wouldn't reccomend it, but I do use it when closing a program lol
Not sure if I worded it properly, but I meant like everything is a bit smaller, so I can fit more stuff on the screen. lol
Old 04-01-2006, 11:49 PM   #22
Bubba
null
The higher the refresh rate the easier the monitor is on your eyes
60 hertz = 60 screen refreshes per second
Be careful when you raise the rate however, if you go too high you could damage your monitor. might want to consult the manual to see what it is capable of
Old 04-01-2006, 11:50 PM   #23
I've seen this before, but the othe way around, everything looks bigger....only on another Forum provider's boards though....
Old 04-01-2006, 11:51 PM   #24
Bubba
null
You can tell if you got a low refresh rate if you look just off one side of the screen and it appears to flicker slightly
Old 04-01-2006, 11:53 PM   #25
Bubba
null
ok right click on the desktop, click properties, advanced tab, and then choose a higher resolution, i'd go one setting at a time higher so you don't overdo it
Old 04-01-2006, 11:55 PM   #26
increasing the resolution will make it so that you can fit more stuff on the screen (I just tried it and it worked) I'd make the resolution higher, but I have parents that use this comp also...
bubba thx maybe that was wrong with my old screen
Old 04-01-2006, 11:57 PM   #27
Mine doesn't have the Advanced tab, this is what it shows on Settings though:
Increasing it by one makes the sides turn black (so the screen is square)
Old 04-01-2006, 11:59 PM   #28
Bubba
null
then you expand the monitor's coverage in teh monitor settings, wiht the buttons in front of the monitor
Edit: and yeah i meant the settings tab, sorry
Old 04-02-2006, 12:02 AM   #29
Mine shows the same....but it appears that I'm already on the snallest setting?.....which seems like the default size to me!
Old 04-02-2006, 12:05 AM   #30
It's a lsptop, so there's no buttons for the screen size anywhere, and when I increase the screen resolution from there, I have to scroll through the screen to see everything
